11-12-2019, 09:34 AM | #1 |
3924
Rep 3,133
NEW RELEASE: Dinan S55 Flash Tuning (F87 M2C & F8x M3/M4)
Featured on BIMMERPOST.com Dinan S55 Flash Tuning (F87 M2C & F8x M3/M4) Part Number(s): D900-S55-S1-W / -HE, D900-S55-S1 Applications:
Description: Dinan has a long and storied past when it comes to engine tuning having introduced our first engine performance chip in the mid 80's — over 3 decades ago. From those early years with chips, followed by engine software and then to our own external control modules we have become experts in nearly every possible way to extract safe, reliable power from the factory powerplant. While we have long preferred the unheard of control and sophistication capable of being achieved from engine software, over the past 6 years that option was not one afforded to us. That changes now with the re-introduction to flash tuning for Dinan with the S55 engine. The first of the next generation of Dinan flash tunes the S55 calibrations are held to the same principles of the past; performance, reliability and safety. Dinan performance engine software is so much more than just tuning up the turbo boost after all. It is a fully re-tuned engine management program that maximizes power while keeping all the BMW factory safeguards in place. Protecting your BMW while giving the most performance is the definition of "Performance Without Sacrifice". Drivetrain and engine components are analyzed for strength then the calibration is tested on the dyno and in the real world for durability and drivability. This next generation of Dinan flash tunes does differ from the past however in that there are many different options to choose from depending on your needs or desires. Whether you want a warranted tune for 93 pump gas when under the factory warranty, an E85 performance tune for maximum performance when outside of the factory warranty, or something in between, chances are Dinan has an option for you. Features and Benefits Common to All S55 Performance Engine Software Variants:
Features, Benefits, Requirements and Power Charts Specific to "Dinan +" S55 Performance Engine Software:
Features, Benefits, Requirements and Power Charts Specific to "Dinan +HE" S55 Performance Engine Software:
Features, Benefits, Requirements and Power Charts Specific to "Dinan Stage 1" S55 Performance Engine Software:
COMPATABILITY NOTICE - BOX CODES & JUNE 2019 FACTORY UPDATE DME box code and bootloader information must be obtained from the vehicle to determine if a vehicle is flashable in its current state. In some cases we will need to create a file for your vehicle. This process could take several days and multiple dealer visits. Vehicles previously serviced or updated after June of 2019 may have received a DME bootloader update from BMW. This bootloader version will prevent the Dinan software upgrade from completing. DMEs with the updated bootloader must be removed from the vehicle, and sent to Dinan HQ to have the bootloader backdated. DMEs sent to Dinan for the backdating procedure will not be opened or physically modified in any way. Once the DME is returned to the dealer, they must still be flashed with the Dinan performance software through the OBDII port. If a previously backdated and flashed ECU is updated with the new bootloader, the above process will need to be repeated. Dinan will not pay labor under warranty to remove and reinstall ECUs that were previously backdated, and then updated by BMW or a third party. DINAN S55 ENGINE PERFORMANCE SOFTWARE FAQ: I already own a DINANTRONICS Elite kit for the S55 engine, can I switch to the flash? Yes, you can trade in your existing DINANTRONICS kit and qualify for a warrantied tune (balance of the factory matching 4yr/50 k warranty) upgrade for only $149.95. If you are already out of warranty or simply want more power you can opt to switch to the full stage 1 options (no factory matching warranty) without any associated upgrade fee. Pricing listed is dependent on trade-in of registered, first-hand units. Used, second-hand units do not qualify. When I purchase a Stage 1 S55 flash do I only have access to one of the octane mappings? When a stage 1 S55 flash is purchased you obtain licenses for ALL the various octane maps. However, only one map can be loaded on the car at any given time so if you wish to use a different octane then what is initially loaded it would require a trip to your authorized Dinan dealer for a reflash. Labor / install charges to perform this service would be at the discretion of the dealer. We recommend loading the octane mapping that is most commonly used for the vehicle (91, 93 or E85 most likely) and only do a map change for special occurrences such as a track day. I have the Dinan +/ +HE tune but want more. What are my options? Dinan+ users can upgrade to the Dinan +HE variant at no charge for more power while retaining the Dinan factory matching warranty provided a Heat Exchanger is purchased and installed as well. For those that want even more power you can opt to switch to the full Stage 1 tunes, taking advantage of more aggressive mapping geared for race fuels, at no additional cost. Switching to these mappings however will immediately cease any factory matching warranty obligation. For all of these scenarios, labor and/or install dealer fees still apply. I do not live near a Dinan Dealer can I still purchase Performance Software? At this time Dinan S55 Engine Performance Software must be installed through one of our authorized dealers. Our dealer list is constantly expanding however so check out the dealer locator often at https://www.dinancars.com/authorized-dealers/ to make sure a new dealer has not begun servicing your area. Will Dinan parts be covered under my extended/CPO warranty through BMW? The Dinan warranty (For Dinan+ / +HE variants) matches the new car 4 year / 50,000 mi warranty but does not cover any extended or CPO warranties. Can I flash my vehicle back to the stock tune? Yes, you have the ability to flash the vehicle back to stock but the process would need to be completed by a dealer. There is no cost to do so from Dinan but you would potentially be subject to dealer labor rates to perform the service. What if I am not happy with my Dinan Engine Performance Software purchase? Is there a return window? All Dinan engine software include a 30-day money back guarantee with no questions asked. If for any reason the owner is dissatisfied with the Dinan engine software, they may return to the place of purchase for a full refund, provided they are within the 30 day period from the time of the initial purchase. Labor or shipping charges are not included in the guarantee and are at the discretion of the place of install. Last edited by Dinan_Engineering; 11-12-2019 at 10:32 AM.. |
11-12-2019, 10:31 AM | #2 |
BimmerPost Supporting Vendor
24384
Rep 191,215
11-13-2019, 12:15 PM | #3 |
1914
Rep 5,112
S58 flash coming?
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
11-13-2019, 12:17 PM | #5 |
761
Rep 1,014
Drives: Porsche GTS 4.0
Dope!
11-13-2019, 12:21 PM | #6 |
498
Rep 697
Drives: Alpine White 2020 BMW M2C
Garage List 2017 BMW X6 M [0.00]
2020 BMW M2 Competi ... [0.00] 1993 Mazda RX-7 [0.00] 2006 Mitsubishi Evo ... [0.00] 2005 BMW M3 ZCP [0.00] 2016 Ducati Panigal ... [0.00] |
nbennettksu1397.00 nicky dj344.50 clee1982797.50 AndrewC198910942.50 behindthen0thing839.50 2SNAILS2085.50 |
11-13-2019, 12:28 PM | #7 |
8271
Rep 18,856
Drives: BMW
For those in the SoCal area, we are an authorized Dinan Flash facility.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-13-2019, 12:49 PM | #9 | |
3924
Rep 3,133
S58 is in development along with a lot of other platforms.
Click a link. Learn something new. =) |
11-13-2019, 01:01 PM | #10 |
3924
Rep 3,133
Depends. The warrantied +HE tune is roughly equivalent in terms of power but the flash also removes the top speed governor and is a more fluid tune just by its nature. If you go the limited warranty Stage 1 tune though there is definitely more power to be had with the flash over the DINANTRONICS Stage 3. Especially once you start going to the racing fuels or E85.
K737.50 |
11-13-2019, 01:05 PM | #11 | |
377
Rep 1,168
IK6SPEED4495.00 |
11-13-2019, 01:07 PM | #12 |
3924
Rep 3,133
11-13-2019, 01:08 PM | #13 |
377
Rep 1,168
11-13-2019, 01:13 PM | #14 |
409
Rep 1,349
Here's the link to the Heat Exchanger as well, I didn't see it in the OP and was trying to find the cost for it: https://www.dinancars.com/product/D7...83-m4-f87-m2c/
Is the plan to make this like APR+ with participating dealers able to handle any warranty claims?
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
11-13-2019, 01:27 PM | #15 |
Primo Generalissimo
4679
Rep 4,031
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Owning an M2C suddenly makes a lot more sense now.
mvigod181.50 |
11-13-2019, 01:28 PM | #16 |
1613
Rep 1,608
@Dinan_Engineering the Dinan Stage 1 is $899 and the Dinan Plus is $1799. Can you clarify a bit more the differences?
"Beware of false knowledge; it is more dangerous than ignorance."
11-13-2019, 01:34 PM | #17 |
4143
Rep 6,926
11-13-2019, 01:40 PM | #18 | |
20625
Rep 8,627
That doesn't over-rev the engine.
11-13-2019, 01:45 PM | #20 | ||
377
Rep 1,168
11-13-2019, 01:48 PM | #21 | |||
377
Rep 1,168
11-13-2019, 02:09 PM | #22 | |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
