09-28-2019, 02:26 PM | #1 |
538
Rep 1,048
CR Spotless - False PPM Reading
I got a CR Spotless (DIW-20) last month but ran into an issue after 4 washes. I live in Los Angeles which I'd assume means the water isn't terrible but I'm not sure to be honest. The meter has been reading 0 PPM on most start ups or reading 6-19 PPM then coming down to 0 once I've ran some water through. I run the CR Spotless with a bypass and only use it to rinse. My whole wash process is with a 2 GPM pressure washer, and I haven't been rinsing for more than 10 minutes per wash.
Today, I turned it on and it was at 330 PPM and continued to climb. I switched to a 15 degree nozzle on my pressure washer and got it to lower a bit into 320 or so. I kept fiddling but no matter what I did, it wouldn't go below 300 PPM. I decided to move forward with the rinse and I'd go back to the trusted MF towel + QD. I use a leaf blower prior to wipe but there wasn't any water spots despite the high reading. I just wiped off some remaining water. Has anyone else ran into this issue? I think maybe just the TDS meter is off. How do I remedy it? |
09-29-2019, 03:05 PM | #2 | |
2164
Rep 5,548
louielouie538.00 |
09-29-2019, 10:34 PM | #3 | |
538
Rep 1,048
Thanks though! |
