09-10-2019, 02:31 PM | #1 |
66
Rep 247
Mystery M leak. Thoughts?
2006 Z4M convertible Pic is of the passenger, bumper corner of the engine bay. Seems the origin of the leak (oil?) is that cylindrical sensor. Any ideas what I'm dealing with here? 35k miles. Has not had any significant service, or need for it, other than routine fluids. Thanks for any ideas you have!
'01 740i Sport; ‘06 Z4M Original owner, no mods
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31 Last edited by Molez93; 09-10-2019 at 10:05 PM.. |
09-10-2019, 05:20 PM | #3 |
66
Rep 247
Yeah. That's the highest oil point I can see.
'14 Lotus Evora S; '13 Subaru BRZ, track & autox car Sold/totalled: E46, E39, 2 E53s, 5 E70s, E31 |
09-10-2019, 05:39 PM | #4 |
10
Rep 31
I just remedied this issue a few months ago by replacing the gasket on the timing chain tensioner (gasket ring part # 07119963418.)
I followed this excellent DIY: http://www.m3forum.net/m3forum/showthread.php?t=433414 Access is much easier on the Z4M. I took all of 20 minutes to swap out and clean up the mess. |
09-10-2019, 05:42 PM | #5 | |
66
Rep 247
09-10-2019, 06:35 PM | #6 |
3854
Rep 3,004
Although the Constant Pressure Valve is located behind the head near the firewall, any chance the oil could have migrated and this is the cause??
Racerbruce
09-10-2019, 07:53 PM | #8 |
66
Rep 247
Didn't see anything near the firewall, although I'll definitely dig into this more to be sure.
09-10-2019, 09:05 PM | #9 |
66
Rep 247
At the risk of revealing my ignorance, if this were an emerging VANOS failure wouldn't I have at least one of the common codes or some performance (including noise) change? If I didn't see the fluid/gunk, I would have zero reason to think anything was in need of attention.
09-11-2019, 12:16 AM | #10 | |
126
Rep 264
It's more like slow O-ring (between VANOS solenoid and the VANOS block itself) deterioration over time. I think those O-rings are made of the same quality rubber as the one in CPV (BUNA?) so it hardens and compresses over time due to high temperature. Oil pressure is extremely high in those channels so oil starts "steaming" through and condensates on parts nearby. But VANOS still has enough room to adjust for pressure loss so you don't see any difference in driving dynamics and no code is thrown either. I was in the same situation 20kmiles ago (at 48kmiles) and eventually rebuilt VANOS with the Beisan's kit. When I started driving the car for the first time after rebuild it really felt like double "sport mode" - throttle response became extremely aggressive and fun Then I ran VANOS adaptation procedure a week later and it returned to normal but I immediately regretted it PS: it still can be the chain tensioner gasket. Or even the front main seal (hopefully not!). So I'd check the area around with a mirror - especially near the VANOS solenoid block. Then wipe it clean as much as you can and check again in 200-500 miles. |
09-11-2019, 12:22 AM | #11 | |
126
Rep 264
But it's indeed worth checking CPV if its O-ring has never been replaced. |
10-05-2019, 08:13 PM | #13 |
66
Rep 247
Replaced the timing chain tensioner and aluminum o-ring washer as that was the only location for any oil leaking. Will update in the future if anything further is worth sharing, although a brief drive up to temp shows no oil.
10-24-2020, 07:14 PM | #14 |
66
Rep 247
1 year and 1,000 miles later = no further issues...though I would guess nobody really cares besides me. ;-)
10-25-2020, 11:09 AM | #15 |
3854
Rep 3,004
Wowie!
Your comment about this great update that it's not important - not true! Great to see this update and to know that the assessment was spot-on as noted in this thread and that you solved it....permanently!
Racerbruce
filtercoffee106.00 |
10-26-2020, 08:11 PM | #16 |
73
Rep 170
I had a similar leak, thought it was the vanos line and while replacing it found the source was the chain tensioner. Ended up tightening it down, ran all summer no leak... might be an easy fix.
10-29-2020, 08:23 PM | #17 |
66
Rep 247
Thanks for the “appreciate” clicks. I’m on a bunch of forums and can’t recall a similar response to any comparable updates I’ve provided over the years. It’s helpful to know it was useful.
