08-29-2019, 06:37 PM | #1 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
driver side vent - upper screw stripped
So after having my LCM replaced, my vent on the driver's side, which has to be removed to replace the LCM, was buzzing. It was loose, I could wiggle it. I pulled it out and reseated it, but the screw that holds it in at the top, the one in the vent with the little black plastic cap over it, doesn't grip anything on the dash side, it's apparently stripped out (the screw itself is fine). Bottom screw no problemo. But I fear the top will continue to vibrate if not secured.
Any simple suggestion on what to use to hold it in? I was thinking of just dabbing some silicone sealant where the vent screw hole piece meets the dash spot behind it. Wouldn't be so permanent that I couldn't pull the thing out again if necessary, but I think it would hold and should definitely prevent vibrations. Any opinions on if this is the best solution, or other suggestions?
'21 M2 Comp
'19 Golf R |
08-29-2019, 06:56 PM | #2 |
2429
Rep 2,704
Drives: Built not Bought 04 Z4 VF
https://images.app.goo.gl/Ckb6nk6Fk9a7mEPg7
I believe there should be one of these behind the vent for the screw to fasten to. If it’s anything like mine, the dash material itself is ripped and the spring nut needs to be silicone in place.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
09-02-2019, 06:55 PM | #3 | |
Dog Listener
703
Rep 7,850
Bingo. Been here, done this. That little clip comes undone easily, and, poof, it's gone into the abyss. |
09-07-2019, 07:45 PM | #4 |
your average JAMF
3101
Rep 4,094
Thanks boys! I managed to spot the clip way back near the firewall, and was able to fish it out with a pipe cleaner. Used a bit of adhesive to hold it in place long enough for me to get the vent back in and the screw properly into it. All is well now, and my dash will finally stop buzzing (at least in that spot!).
'21 M2 Comp
'19 Golf R |
09-08-2019, 04:13 PM | #5 | |
Dog Listener
703
Rep 7,850
Nice find and fishing! |
