08-03-2019, 09:17 AM | #1 |
201
Rep 277
DIY for spun crank hub?
Would be interesting to see a DIY for a spun crank hub with both the aftermarket crank hub fix and just with a new bolt and retime. I'm assuming (hoping) this is something the garage mechanic with a 2 post MaxJaxx lift could accomplish.
Tutorials found thus far- CBC (Crank Bolt Capture) DIY - https://f80.bimmerpost.com/forums/sh....php?t=1594892 Crank Hub Fix and retime - TBD as more information is compiled. Last edited by noone; 08-05-2019 at 03:24 PM.. |
08-03-2019, 04:00 PM | #3 |
BimmerPost Supporting Vendor
8250
Rep 18,839
Drives: BMW
We have an overview listed here:
▀▄ eas | VTT "SplineLock" CrankHub Installation Overview for S55 https://f80.bimmerpost.com/forums/sh....php?t=1561598
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-03-2019, 07:42 PM | #4 |
4933
Rep 3,810
The only thing that's DIYable is the crank bolt capture. The rest requires special tools that would not be economical as most professional shops don't even have them.
08-05-2019, 07:16 AM | #5 | |
201
Rep 277
So if my hub spins, my only avenue is to take it to BMW? I'm in Jacksonville FL. |
08-05-2019, 08:43 AM | #6 | |
227
Rep 369
As far as a CBC goes: Lift car, Remove intake, remove radiator fan, remove bolts on the crank pulley, apply CBC, lock tite and install new bolts to 25’lbs. It’s pretty straightforward. If you feel like driving to central fl, I can do it.
///M3
08-05-2019, 08:59 AM | #7 | |
201
Rep 277
CBC does sound easy since you just have to slap it on. I wonder if the CBC solution alone is permanently resolving this issue? Any long term users of the CBC-only solution out there with Stage 2 or > tuned cars? Does the CBC add any appreciable weight or anything along those lines that would change the way the engine runs, adds vibrations, etc.? |
08-05-2019, 11:35 AM | #8 | |
227
Rep 369
It weighs 1.3 oz. I don’t notice any change in the operation of the engine. I also haven't read of any cases of the hub spinning with a CBC installed, but there have been cases of aftermarket hubs spinning without a CBC installed.
///M3
08-05-2019, 12:23 PM | #9 | |
646
Rep 1,336
Scope out amazon. I've considered pulling the trigger on the kit. |
08-05-2019, 03:19 PM | #10 |
201
Rep 277
Interesting. I kind of figured this as I don't see why there would be these mega tools which cost 100's and thousands of dollars needed to time an engine. And to confirm, you do NOT have to drop the engine to install the Crank Hub Fix (from whatever vendor)? Great news if true. I'd rather work on my car myself in the comfort of my garage on my lift than take it somewhere.
08-05-2019, 03:22 PM | #11 | |
201
Rep 277
08-05-2019, 03:43 PM | #12 | |
Rep 18
I got the same kit on Ebay. And free shipping lol. The kit is not that much money really and if your going to be modding your F80 yourself its worth while to have i think. |
08-05-2019, 04:14 PM | #13 |
201
Rep 277
Is this the kit that will time and lock the crank?
https://www.ecstuning.com/b-cta-tool...t/cta2886~cta/ Last edited by noone; 08-05-2019 at 07:09 PM.. |
08-05-2019, 06:20 PM | #14 | |
227
Rep 369
///M3
08-05-2019, 06:55 PM | #15 | |
508
Rep 648
Drives: 2016 F15, 2015 F83
2016 F15 X5 50i M-Sport
2015 F83 M4 |
TX PETE10.00 MisterF80M31058.50 |
08-05-2019, 07:07 PM | #16 | |
201
Rep 277
The hypothetical here is that I tune my car, hub spins, and I want to fix it myself in my home garage. Edit - So you also need to buy this? https://www.ecstuning.com/b-genuine-...IaApYaEALw_wcB Last edited by noone; 08-05-2019 at 07:12 PM.. |
08-06-2019, 07:34 AM | #17 |
99
Rep 508
I have the MaxPSI hub and the shop that was lined up for the install totally dropped the ball on me.
So I am also looking for more info on what tools are needed to DIY this at home. I have tried 3 different local shops and they are all either unequipped or not willing to drill the crank... |
08-06-2019, 09:04 AM | #18 |
4933
Rep 3,810
Also keep in mind, if you are looking to DIY, that there isn't really enough data to prove one solution is better than the other despite the marketing. So you might spend thousands on a preventative measure and think you're good, but you may not be.
08-06-2019, 10:57 AM | #19 | |
201
Rep 277
08-06-2019, 01:02 PM | #20 | ||
99
Rep 508
Drilling the crank is not a new, unique, or scary process. I have personally done several engine swaps, replacements, turbo builds, etc. I just do not have the tools for this particular job... |
08-06-2019, 01:17 PM | #21 |
4933
Rep 3,810
I thought I read somewhere that someone sheared the pins, but I'm not 100% on that. Point is - failure rates are so small that it's going to take years to have enough data to truly say that one is better than the other.
