08-01-2019, 11:53 AM | #1 |
Rep 3
Horn goes off when I turn the wheel at all?
Greetings all,
I woke up to some frustrating issues with my 2003 Z4. I started the car as usual but found that whenever I did anything in the car, the horn would go off. If I moved the steering wheel at all, it would sound until I stopped moving the wheel. If I changed the gear, the horn would go off (I never drove it, just moved it to neutral). Clutch in, same thing. The issue was remarkably sensitive. Even lightly touching the wheel would make the horn go. I didn't do much more testing than this because, frankly, it was annoying and I didn't want to bother my neighbors. I really hope someone on this forum may be able to help me. The little research I have done suggests that "the SIR COIL wire is shorting out to ground when turning the wheel" and likely needs the steering wheel pulled. The issue described in this research is similar but not nearly as sensitive as what I am experiencing. It may be different. Thank you in advance for any help/advice you can offer! |
08-01-2019, 03:08 PM | #2 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Pop the airbag out first, it's pretty simple, lots of videos on Youtube and see if you spot any pinched/exposed wires. I expect that you will find something out of the ordinary there.
E86 ///M Coupe - Imola Red/Imola Red
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
08-01-2019, 03:37 PM | #3 |
Rep 3
Thank you for this. I posted the same question on another Z4 forum and received a similar suggestion, so this will definitely be my first course of action. The other guy said that it can often be a screw or piece of metal that gets stuck in such a way that it completes the circuit for the horn. Thank you again for the response. I will update this tomorrow when I pop the airbag off.
08-02-2019, 02:23 PM | #5 |
851
Rep 4,057
Wow! I was just in New York with the family for a holiday to see a couple of shows and it seems that everyone there has the exact same problem!!
Let’s hope the suggestions above get this fixed for you fast! |
08-03-2019, 04:49 PM | #6 |
880
Rep 2,547
Drives: Z4MC-X3-35i-525i, Corrado G60
Just checking, is it the horn or the alarm siren going off?
