07-28-2019, 11:13 AM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Ultimate Enthusiast Owner's Guide - Help Needed
As the years have gone by, Zpost has amassed tons of great info but I've found it increasingly more difficult to find that "great thread on A from X years ago." Search function gets the job done, but I think it'd be great if we had a consolidated *sticky* that contained links to preventive maintenance items, common repair DIYs, known failure items, etc... basically the ultimate Z4 Enthusiast Owner's Library
Ideally the thread could include:
The focus however is more about maintenance and less about mods. I'm happy to take a stab but would rely on folks here to send/review the info. Again, not looking to recreate the wheel (and write up new DIYs) but simply have a single source of pre-existing information, links and attachments. Last edited by 3002 tii; 07-29-2019 at 11:23 AM.. |
07-28-2019, 11:14 AM | #2 |
2286
Rep 12,565
*Work-in-Progress* - to be updated regularly
Owners Manual & Maintenance Related
Pelican Parts Repair Guides for 2003-08 Z4:
Approved Fluids BMW LL-01 Approved - Jan 2008 (attached) Last edited by 3002 tii; 08-11-2019 at 11:31 PM.. |
07-28-2019, 11:18 AM | #3 |
2286
Rep 12,565
1. Soft Top Care
2. Audio & Electronics
3. Suspension & Alignment
4. Braking 5. Interior & Lighting
07-29-2019, 09:45 AM | #6 |
31
Rep 135
When I bought my Z I beg/borrowed/stole from around the forums and created (or maybe I borrowed & customized ) a spreadsheet that I use to track maintenance. It's mostly based on the Mike Miller guidelines and can be accessed here.
You should be able to view and copy from that link as needed. Hope it helps.
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i |
07-29-2019, 11:24 AM | #7 | |
2286
Rep 12,565
08-11-2019, 06:44 PM | #9 |
Dog Listener
703
Rep 7,850
Suggested topics to add, I'll add more links as search time permits.
Transmission and engine mounts. Full disclosure, one of these is mine. Link1, link2. And, why didn't I bookmark this, recently someone posted about a DIY exhaust side engine mount heat shield... Firewall brace groan and fix (often sounds like the dash/inst cluster). CDV delete, clutch stop Performance pedals Upgrade/strengthening of the from ARB mounting points Easy peasy camber bolt addition S54 essentials: bearings, VANOS rattle fix, exhaust hub, valve adjustment SSK install Weather strip replacement, other preservation steps FCAB replacement, FC arm replacement |
08-11-2019, 07:30 PM | #10 | |
321
Rep 528
Drives: E86 Z4MC; E92 M3
https://www.zpost.com/forums/showthread.php?t=1234185 I'll also try to find some links and posts for this, it's a great idea.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
Finnegan703.00 |
08-11-2019, 07:55 PM | #11 | ||
Dog Listener
703
Rep 7,850
Thanks! |
08-11-2019, 11:35 PM | #12 |
My other car is on Mars
636
Rep 3,124
I think it's still effective.
Due to my oil leak that area is such a mess I don't even want to look. Also, the Bimmerworld mounts are such beasts compared to the VT it's probably fine. The old girl just passed 195k miles.
Warning: May contain traces of nuts.
