07-21-2019, 08:56 PM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Air Dam Solution for Front Splitter
For those running front splitters like APR, do you have an air dam to fill that center gap (sorta like the M stache)?
07-22-2019, 05:41 AM | #2 |
Down Under!!
1621
Rep 4,294
Pretty sure Ian or Ron had a solution to this, think it was a piece of lexan that fit in-between the splitter and the bumper, about and inch thick.
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by |
08-02-2019, 09:57 AM | #3 |
366
Rep 1,373
My brother and I both bought the ones made by Ian back in the day. His cracked so I ended up making a new one from some flexible house trim you can source at home depot. Its easy to cut, paintable and very flexible so it easy to install.
I also ended up making up both lips to go on the leading edge of the APR splitter from the same stuff. Looks a bunch better then it being raw and adds a bit of meat to the splitter. I'll take a pic of what I did tonight.
07 Z4 M Coupe AW/IR |
3002 tii2285.50 |
09-02-2023, 09:30 PM | #4 |
2286
Rep 12,565
4 year bump, finally going to mount my splitter that’s been sitting in the garage all this time. Anyone else come up with an air dam solution?
09-03-2023, 06:17 AM | #5 | |
952
Rep 781
I'm thinking of using it as a vertical dam, if the bottom contacts the road surface it will just wear a bit off the lower edge, it's flat black.
2008 E86 M coupe
E93Seattle (Racerbruce)799.50 |
09-03-2023, 08:39 AM | #6 | |
2286
Rep 12,565
