06-06-2019, 02:37 PM | #1 |
111
Rep 186
Work VS-XX Fitment
Sup Fellas. Need some advice from the experts..
I'm in the market for a set of 19in or 20in Work VS-XX wheels in matte bronze and need assistance in getting the right specs for fitment on my 16' M4. I almost purchased the following wheels but found out last minute that the specs did not fit M Models: https://www.ravspec.com/shop/work-vs...0-bmw-fitments. WORK VS-XX Matte Bronze (MHG) Finish Glossy Bronze Anodized Barrel Black Finish Assembly Bolts 20×9.0 +32 (O-Disk) 20×10.5 +38 (O-Disk) 5×120 (BMW fitments) 9.0 +32 Lip Size: 72mm (~2.8″) 10.5 +38 Lip Size: 84mm (~3.3″) Fitments Guide: Most BMW, non-M3. Will not clear caliper. My question is what specific spec would be needed to have this fit on my M4? I am currently lowered on KW HAS Kit with 12mm/15mm spacers so I can adjust accordingly. Also, I would like to get the biggest lip as possible for these wheels and would getting 19in VS-XX allow me to have a bigger lip? Thanks in Advance! |
06-06-2019, 03:52 PM | #2 |
722
Rep 2,342
9" wide front is pretty skinny. But a 255 should be fine and I'd consider that the max optimal since anything wider in front would muffin top and have poorer response.
+32 in front you could run a spacer to get as low as +17 - +20 since front is a 9" Rear you can run 305 and be ok even though 10.5" and 305 isn't really optimal either. 295 is better. probably no more than a 5mm spacer for if you do a 305 and maybe a 10mm if you do a 295. |
TypeDre111.00 |
06-06-2019, 04:26 PM | #3 |
6586
Rep 5,305
Good thing you didn't buy those. Work makes a VSXX fitment specifically for the F80. The specs are...
20×9.5 +17mm T Disk, Step Lip, 5×120 (59mm lip) 20×11.0 +34mm R Disk, Step Lip, 5×120 (72mm lip) I think 20s look better on a 3-piece stepped lip wheel. The F80 specific VSXX has a pretty deep lip if you ask me. https://www.ravspec.com/shop/work-vs...-step-lip-m3m4 |
TypeDre111.00 |
06-07-2019, 05:01 AM | #7 |
111
Rep 186
Can you recommend camber plates for the fronts and tires specs I would need for them not to rub? Thanks!
06-07-2019, 05:04 AM | #9 | |
111
Rep 186
06-07-2019, 07:59 AM | #10 | |
1274
Rep 1,290
Note that while well built, made in jpn, these puppies weigh in 30-35lbs last I checked. I'm not a stickler for wheel mass like the pointy elbow brigade here, but you could def feel it and I personally never got used to it. Again the stuffed look is mesmerizing. Pick your poison.
Dry sump flat six
TypeDre111.00 |
05-14-2020, 04:21 PM | #11 | |
28
Rep 195
