ZPOST
  TireRack
      05-04-2019, 12:12 AM   #1
Danny_P
Drives: 06 Z4C 3.0si
Exhaust Backfire
I have a 06 3.0 si. Its automatic sadly. But I was wondering how I can get it to backfire. I've done it unintentionally, but how would i get it to backfire intentionally with my stock exhaust? Would I need a tune for that and if so where would I find the Maps for it?
      05-04-2019, 12:30 AM   #2
StickMon
My other car is on Mars
StickMon's Avatar
636
Drives: 2006 MR
Not sure it'll work with auto or stock exhaust, but I can get consistent 12 gauge shots out of my ///M with aftermarket exhaust by gently tickling right at the edge of deceleration at about 3000 rpm.
Warning: May contain traces of nuts.
      05-05-2019, 07:49 AM   #3
garz747
286
Drives: 07 Z4MC 01 330i 18 X3 M40i
You can blow out your muffler with backfires. The newer Ms and other performance cars have the farts on decel from the ecu and are safely done.
      05-05-2019, 05:06 PM   #4
abelgonzaleZ4
61
Drives: 2006 BMW Z4 SilvrConvert 3.0i
I have an 06 3.0i roadster. Did a muffler delete and sound awesome.
Sounds like an M.
Cut your off and add a muffler tip.
      05-07-2019, 10:27 PM   #5
Danny_P
Sounds like an M.
I think I might just do that. What muffler tip would you recommend? Or should I do a resonator delete?
      05-08-2019, 09:53 AM   #6
pokeybritches
pokeybritches's Avatar
479
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
You need to get rid of your cats and get a tune if you want pops/crackles or even flames. Extra fuel needs to be dumped at no load and high rpm, and ignition timing has to be retarded in those areas of the timing map. Your cats will quickly self destruct if you do this on a stock car.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
zpost
