ZPOST
  TireRack
      04-19-2019, 06:08 PM   #1
RickS
16
Drives: 2006 Z4 3.0SI
06 z4 roadster with M seat seat belt question
I bought a Z4 roadster over the winter, it has M seats. Had it parked for the winter and I just start driving it a lot and noticed that the shoulder part of the seat belt rubs against my neck and is uncomfortable. I'm 6'.
Any one else have a similar issue, if so how did you get around it? I'm thinking a seat belt extender to move the buckle to the left.
Thanks.
      04-19-2019, 06:38 PM   #2
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
Thanks.
Will adjusting the seat help?
Follow for latest mods
      04-19-2019, 07:02 PM   #3
StickMon
My other car is on Mars
StickMon's Avatar
636
Drives: 2006 MR
http://www.tiddybearcomfortstrap.com/
Warning: May contain traces of nuts.
WickedNy225.00
      04-19-2019, 07:50 PM   #4
KevinC
your average JAMF
KevinC's Avatar
3101
Drives: '21 M2 Comp, '19 Golf R
"tiddy" bear. Brilliant!
'21 M2 Comp
'19 Golf R
      04-19-2019, 08:52 PM   #5
ZMCoupe
36
Drives: 2007 M Coupe
This always annoyed me so I put a small bolt through the guide holding it lower, it helps keep it away from my neck. Also it does need impede the function of the seat belt at all.
      04-20-2019, 01:28 AM   #6
WAMz4
WAMz4's Avatar
45
Drives: 2006 Z4 3.0si Roady
I just use a simple seat belt clip fromWalmart, It holds the shoulder strap at my stomach and over my shoulder away from my neck.
https://www.walmart.com/ip/WalterDra...-of-2/37284474
The Internet said it. I believe it. That settles it!
      04-21-2019, 06:23 PM   #7
RickS
16
Thanks for the suggestions! I think I'm gonna pass on the Tiddy Bear, not my style... and try the clip.
Rick
      04-21-2019, 07:02 PM   #8
Huz-Z
Huz-Z's Avatar
851
Drives: Z4 3.0si, 328 XDrive, X5 35i
Roadster Solutions sells seatbelt pads that cushion the belt against the occupants’ shoulder. See:
http://www.roadstersolutions.com/cgi...33787c9eeb1551
Scroll down to see them. $49 for a set I think.
There are a number of different ones on eBay like this
https://www.ebay.ca/itm/2Pcs-Black-C...0AAOSwrmRb~qtQ
      04-21-2019, 07:06 PM   #9
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
There are 2 types of belt deflectors made for the m seats.
Do you have the old or new style.
I dont know if they make any difference (I have the old, never tried the new, but don't have any problems), but if you have the old, you could try the new (not vice versa, the old one is not sold anymore afaik but I might be wrong)
I'm taller than 6' though.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
      04-22-2019, 07:42 AM   #10
Hokie6
Drives: 2008 Z4 Coupe 3.0Si
Just picked up a set of these as I find the belt gets pretty tight and uncomfortable (also 6' so know what you're talking about!)
https://www.aliexpress.com/item/Onev...1af04c4dip0XZq
      04-22-2019, 09:47 AM   #11
ShakyDog
ShakyDog's Avatar
183
Drives: 2007 Z4 3.0i Alpine White/Red
I have the non-sport seats and my belts also do this, I tend to always wear a collared shirt. My Lucy want me to dress up for her
Steve
      04-22-2019, 01:52 PM   #12
RossBMWZseries
226
Drives: '11 E92 328i LCI & '06 Z4MR
5'10 reporting here....wait, we're talking about heights right?
All jokes aside, the seat belt also rubs on my neck, itches pretty bad once i get home after a 30 minute drive
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      04-22-2019, 04:56 PM   #13
wdb
dances with roads
wdb's Avatar
4732
Drives: '07 E86, '02 996, '95 Seven
I had someone give me one of the pad-style items. I hated it. All it did was make the bad thing worse. I also tried lodging things in the guide on the seat in an attempt to keep the belt a bit lower. It might work for a 6-footer but I'm 5'10" and it did nothing for me.
I just reach up and move it occasionally. I've driven 10+ hours without being overly bothered.
      04-22-2019, 05:31 PM   #14
StickMon
StickMon's Avatar
636
Drives: 2006 MR
I have wraps similar in design to the ///M wraps linked in post #8, but mine are plush and fluffy generic black. Feels kinda nice.
Probably came from Walmart or Target. Not sure. Wife bought a sack of them years ago for all of the cars/trucks.
zpost
