04-17-2019, 07:50 AM | #1 |
157
Rep 1,107
S54 Squeak
Z4M/S54, 75K miles on it. For about 6 months now I've had a very short duration squeaking from the engine when I first start up my car in the morning. It only happens when the car has been sitting at least overnight. It sounds like a noise caused by rotation. I'd say it goes away after 4 seconds. A few months ago I pulled the belts, checked the various pulleys to see if they might be the cause (I changed all but the A/C idler pulley at 50K miles) and played around a bit but couldn't find the source of the noise. The noise has come and gone and come and gone.
This morning on startup the noise was the loudest I've heard it, and again it quieted down in a few seconds. When I got to work (25 minute drive) I restarted the engine...no noise. Has anybody experienced this? I'm starting to think it might be the waterpump going south. I would say it could be a cooling fan, but that wouldn't kick on right at startup, would it? Thx. |
04-17-2019, 09:21 AM | #2 |
1136
Rep 2,867
Drives: Anything
I had similar squeak for the past few months, but haven't heard it in the past month or so. Mine is much shorter, in duration, than yours - only about a second or so, almost sounds like a bird chirp. Same as you, it only happens on cold startup - on first start. My belts were changed at ~46k mile or about 3 years ago. It's currently sitting at ~59k. I'm curious to hear what you or other find.
04-17-2019, 10:11 AM | #3 |
157
Rep 1,107
I definitely think I'm going to change the water pump out. There's a great DIY and it doesn't seem hard, just a bit long at about 3-4 hours. Maybe I'll change out the reservoir and get that out of the way..but then should also change the hoses...and maybe the radiator. Aaahhhhhh!!!
04-17-2019, 10:28 AM | #4 |
77
Rep 177
Is it similar to this sound at around the 4-5 second mark?
https://www.dropbox.com/s/iel91njxnj...15.56.mov?dl=0 I first noticed it about a month and a half ago, but couldn't figure out where it was coming from. Similar to both your cases, it only happened on cold starts. Surprisingly, last weekend when I started the car up, the noise was gone. |
04-17-2019, 10:52 AM | #5 |
286
Rep 679
My E46 330 has been doing this forever. Dealer changed out tensioners years ago -still a problem when cold.. Im guessing its a tensioner issue on the Z although mine hasnt done this.
04-17-2019, 12:34 PM | #6 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
Secondary Air Injection pump? When (ever?) were the belts last changed?
'21 M2 Comp
'19 Golf R |
04-17-2019, 01:27 PM | #7 | |
157
Rep 1,107
I don't think so. Mine has been more of a slight "chirping" sound. That's why I think it is caused by rotation, as in possibly a dry bearing (like in the water pump).
04-17-2019, 01:39 PM | #8 |
157
Rep 1,107
Just had a thought. I think I'll remove the water pump belt and let the car sit overnight. Then in the morning I can turn the water pump pulley by hand, isolated from the rest of the engine, and see if I get the noise.
I usually get to the tensioners from below (certainly the A/C one). Hope I can get to the top tensioner from above. (belts and 2 of 3 pulleys were done at 50K miles) Last edited by elerner61; 04-17-2019 at 03:24 PM.. |
04-17-2019, 06:32 PM | #9 |
your average JAMF
3101
Rep 4,094
^^ great plan, good luck
'21 M2 Comp
'19 Golf R |
04-18-2019, 08:38 AM | #10 |
157
Rep 1,107
So..I removed the belt this morning (pushed it out of the way really) and spun the water pump by hand. Felt smooth, no noise and no binding feeling. Pushed and pulled on the pulley, tight, no movement. I then started the car...no squeaking noise. I let it run for 10 seconds and turned it off. Waited 5 seconds and restarted...again no noise. Back under the hood I spun the alternator by hand, no noise, no binding. I didn't get a chance to spin the power steering pump by hand (if that's even possible). Will try to do that.
So at this point it would seem I've isolated the noise to those components. I think I'll probably swap out the water pump as that was on my list to do soon anyway, as that is the most critical component of the three, maybe do the expansion tank at the same time. The pulleys only have 25K miles on them so as long as they still feel smooth probably keep them unless the squeak doesn't go away. Any thoughts? Always appreciated. Last edited by elerner61; 04-18-2019 at 09:40 AM.. |
04-29-2019, 11:47 AM | #11 |
157
Rep 1,107
So I finally dug into the water pump swap out the past couple of days. One item not covered in any of the videos/DIYs I see is that for the Z4M (and not M3) there is a short thermostat coolant pipe that enters the thermostat housing. There is actually an O ring on both ends of the pipe but the DIYs only show changing the exposed O ring. I tried to pull off the pipe to get to the inner O ring but that sucker is tight. Not sure if I should just leave it, or have another more aggressive go at it. Thoughts?
[Edit] Muscled and wiggled it out. Wasn't so much as tight, just had to do many "micro wiggles". Last edited by elerner61; 04-29-2019 at 12:58 PM.. |
05-09-2019, 09:52 AM | #12 |
157
Rep 1,107
So after 5 or so cold restarts it seems like that noise was (cringes when saying) the water pump. All has been quiet and good. The pump I pulled out felt very solid, no play in the bearing at all. The only difference when comparing to the new pump is that when lightly spinning it the old pump felt a little notchy while the new pump was smooth.
XMetal1136.00 |
05-09-2019, 12:38 PM | #13 |
1136
Rep 2,867
Drives: Anything
Thanks for the update! Now, I know what to look for when my chirp turns into a longer duration squeak
05-21-2019, 09:57 AM | #14 |
157
Rep 1,107
Well, it's back, the squeak, chirp. Actually it re-appeared 5 days after my last post. So it's not the water pump. At this point since it can't be anything that will cause catastrophic damage I guess I'll monitor and see if it gets worse. I do have spare idler and tensioner pulleys so I may swap those out when I do my power steering hose in the near future.
05-08-2020, 06:07 AM | #15 |
23
Rep 125
Hello
Any update on this? My Moupe just started doing this exact thing like yours. First cold start of the day. Rpm related., disappears after 30 seconds |
05-08-2020, 08:28 AM | #16 |
157
Rep 1,107
I still haven't done the power steering hose. Life and a new daily driver have gotten in the way (Macan).
The noise has stopped happening though for the most part. It certainly hasn't gotten worse. One of life's great mysteries continues! Maybe the new tires I'm putting on will make it start happening again. |
