03-27-2019, 06:07 PM | #1 |
449
Rep 229
Valve Adjustment
Hi. I'm about to adjust the valve clearances on a 2008 Z4 M Roadster. I'll need to slowly spin the engine at the crankshaft as part of the valve adjustment procedure. To get access to the crankshaft nut, am I correct that the wide black plastic "cover" at the front of the engine, and the electric fan, both need to be removed? Also, while I'm here, am I also correct that turning that crankshaft nut clockwise (from the passenger side to the driver side) is the correct direction?
Thanks for your help!! Ted |
03-27-2019, 06:15 PM | #2 | |
160
Rep 892
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
04-03-2019, 06:58 PM | #5 |
64
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Instead of paying $60 for the special crankshaft socket buy this Water Pump Shaft Nut for $10 https://www.bimmerworld.com/Cooling/...Shaft-Nut.html
Install this nut and leave on. BTW no need to remove the fan shroud.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
04-03-2019, 08:06 PM | #6 |
My other car is on Mars
636
Rep 3,124
No special crankshaft socket needed on the Z4.
That's for the M3 with mechanical fan. Just need a whopping metric socket. I can't remember what size. 30 or 32mm, maybe. Somebody please chime in.
Warning: May contain traces of nuts.
04-13-2019, 05:12 PM | #8 |
948
Rep 1,910
Ted,
As an alternative to turning the engine with a wrench on the crankshaft nut, you could put it in sixth gear and push the car by hand. (Unless it's an automatic, of course.) Good luck with the adjustment! Rick F.
For all my trips, check out http://rsftripreporter.net.
