03-25-2019, 08:04 PM | #1 |
Nathan
Rep 10
HVA design flaw on Z4
Hi people,
I heard that the N52 engines have a design flaw that causes the HVA to tick or tap... Since I have an 03 z4 with the M45B25 engine (correct me if im wrong), does it have the same design flaw that causes the lifters to tick like the n52? My car is out of warranty and after hearing that a cylinder head costs $7000 to replace, I'm kind of worried that it'll eventually happen to me. |
03-25-2019, 08:31 PM | #2 | |
#buildnotbought
10859
Rep 4,893
The M54 engine has no valve lifter problems like the N52 has. But you will probably encounter other problems as the car ages (although nowadays virtually all common problems on the z4 with m54 engines can be solved relatively easy or cheap with alternative fixes invented through the years and aftermarket solutions)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
lawms980.00 |
04-03-2019, 09:02 AM | #3 |
General
17315
Rep 18,737
The N52 really doesn't have lifter problems either. Early engines built prior to December 2008 can have lifters that make noise if the engine sits a lot. The noise does not affect engine longevity nor performance. Both of my N52 fall within the production dates of noisy lifters. Neither engine makes noise. One engine has 370,000 miles, the other has 94,000.
04-03-2019, 09:12 AM | #4 | |
851
Rep 4,057
After almost ten years and lots of cold weather Canadian starts, the lifters have been perfect.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
lawms980.00 |
04-03-2019, 11:55 AM | #5 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
The M54 does not have the same hydraulic valve design as the N52. The ticking common on the N52 is not present on the M54 that I am aware of?
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
lawms980.00 |
Tags |
hva, lifters, m45b25 |
