03-25-2019, 01:02 PM | #1 |
102
Rep 344
New Owner - I'm in love
Hey everyone,
Just bought myself an 06 33k mile M Roadster. I've had an F80 M3 for almost 4 years now as well and this car is making me forget all about it. I am absolutely blown away at how amazing the raw driving experience is in a tiny roadster like this with that awesome S54. I don't even find myself missing the torque from the S55 to be honest, which was the only thing I was worried about when buying this car. I may be in the honeymoon phase but this is one of my favorite cars I've ever driven. Just had a few thoughts and concerns -1-2 gear shifts are tricky, I can see why people are grinding gears. I am not having that issue thankfully but am still not getting a very smooth shift every time. If anyone has any suggestions they'd be welcome. Only time I get it smooth is if I shift fast and get the timing exactly right or if I let the clutch out in 2 motions. So clutch in, shift into 2nd fast, clutch out to engagement point and hold for like a millisecond then release. It works the syncros just a bit but feels the most natural. -No cold air from left vent. Not sure if common issue or not -Horn doesnt work. I read that there are 2 physical horns so I'm thinking the chances that they are both defective is low so I hope its just a fuse -The car came with the aftermarket center armrest thats way too high and gets in the way of comfortably shifting. Tried tearing it off but I guess that adhesive is super super strong so I'm gonna tell my shop to take a heat gun to the corners and try to pry it off. Hopefully wont rip my trim apart -Suggestions for bluetooth for music? Is the best way to install an AUX input and buy one of those small bluetooth things that plug into the AUX? -Does anyone know how I can find out if valve adjustment service was done? Previous owner had maintenance records that show Inspection 1 which he claims were when the valve adjustment was done but AFAIK they are normally done on inspection 2 which I don't have a record of -Will be changing oil and intake filter but I am not used to owning an older vehicle. Is there any other maintenance items that I should handle? Want to make sure I handle all preventative stuff. Not sure if any fluids should be changed just because of the age of the car rather than the miles. Maybe I should do tranny fluid with an oil change? Super excited to keep driving this awesome thing. Some pics just because Last edited by ryank382; 03-25-2019 at 01:12 PM.. |
03-25-2019, 01:06 PM | #2 |
1692
Rep 685
For the 1st 2nd gear issue it's most likely the clutch delay valve. You can remove it with no needed parts. Made a huge difference in my 2.5. Pretty sure the M has it also, hopefully someone else can chime in. Enjoy your car!!!
03-25-2019, 01:27 PM | #3 |
Rep 28
Drives: 2006 BMW Z4 3.0 si (N52)
In Re: to your aux comment... I use one of these and it is very unobtrusive and works very well!
https://www.amazon.com/AUKEY-Transmitter-Bluetooth-Wireless-Handsfree/dp/B07F5H84HT/ref=sr_1_16?crid=1CR5HXZB0ZAMU&keywords=aukey+blue tooth+receiver&qid=1553538298&s=gateway&sprefix=au key+bluetooth%2Caps%2C159&sr=8-16 |
03-25-2019, 01:56 PM | #4 |
1138
Rep 2,867
Drives: Anything
While removing the clutch delay valve helped a bit, it ultimately comes down to timing on the ///M. After 10yrs+ with the ///M, I still feel like a noob on the 1-2 shift, especially if I don't drive it often. Not coming completely off of the gas help too, but I just have to remember that 1-2 shift needs to be done differently from all other shifts.
03-25-2019, 02:38 PM | #6 | ||
102
Rep 344
Sounds good, I'm not expecting any damage to the console but rather to the trim underneath so I'll let you know when it's out |
03-25-2019, 03:10 PM | #7 |
127
Rep 1,772
Drives: 2007 Z4M Coupe
Congrats! Those pics look like right by Son Cubano in North Bergen area on River Road. I am a little further up north in Edgewater although the car has not come out of storage yet.
regarding your questions. 1-2 shift is definitely tricky. Taking out CDV makes it a little more better but still not perfect. What works for me is changing gears in a higher RPM and not granny shifting 1-2. Get the AUX installed and then get a BT to AUX system. Look around the forum, there are instructions for both.
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust Last edited by SCHMOUPE; 03-25-2019 at 03:26 PM.. |
03-25-2019, 03:48 PM | #8 |
23
Rep 209
Drives: Z4M roadster
I suggest you consider replacing the engine and gearbox mounts with something more robust (VibraTech/Rogue) The engine/gearbox is heavy and moves around on the (old) standard mounts, which hinders shifting. These made a much bigger difference on my car than the cdv elimination.
2006 Z4M roadster. Interlagos Blue, black extended leather with carbon trim. Apex EC7 8.5/9.5 x 18 rims, Strong Strut brace, KW V3s with RE rear shock mounts, Vibra Tech and Rogue engine/transmission mounts, Stromung exhaust, CDV delete.
03-25-2019, 04:03 PM | #9 | ||
102
Rep 344
03-25-2019, 04:29 PM | #10 |
286
Rep 679
Welcome. Try applying some pressure to the left as u pull the shifter to 2nd gear. Many forum members have had good results with royal purple syncromax trans fluid although Ive yet to do it myself. Forget the CDV. Clutch bites perfectly on my coupe- exactly half way.
03-25-2019, 04:46 PM | #11 |
7494
Rep 12,310
Welcome! I like the F80, but wasn't quite in love with it like my current M's. The Z4M is refreshing that it came out of the factory like this, and the Roadster adds another layer of fun IMHO.
Regarding the trans, I also recommend changing the fluid. I went with Redline and it made my shifts so much smoother! Fluid was filthy. Mine is out of commission until I do rod bearings and VANOS, and I miss it terribly. Congrats on a great choice! |
03-25-2019, 07:33 PM | #12 | |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
Also add a clutch stop, either via Ebay or Rogue Engineering.. https://goo.gl/xUKgMw
'21 M2 Comp
'19 Golf R |
03-25-2019, 07:45 PM | #13 |
your average JAMF
3101
Rep 4,094
Some other comments..
Valve adjustment is scheduled for both Inspection 1 and 2 (and future ones beyond that). So if a dealership performed 1, then it should have included it. Lots of options for audio while retaining the stock head unit. I'm currently streaming SiriusXM and whatever else (my own library, etc) from my iPhone to the aux port. You need a lightning-to-aux cable to do this, with a DAC in the cable to convert the digital signal out of lightning to analog for the aux port. I use this cable from Amazon: https://goo.gl/EYbdZa Obviously if you use an Android phone, you would need either a standard aux cable if your phone has a headphone jack, or possibly USB3 if a newer phone without. Grom Audio also makes a nice little box that allows you to do lots of stuff, including Bluetooth audio, USB dongle, etc... https://gromaudio.com/store/all-bmws.html You do NOT need their DSP adapter, even if you have the "premium" audio setup with DSP, because the Z4's DSP is analog. Confusing, but that's the deal. Set up a free account at mycarfax.com, and plug in your VIN. It will pull up whatever service history has been reported, and it's completely free. A lot of times you'll get a pretty complete history picture there, depending on who has been servicing the car. As for other maintenance items - I recently bought a decade-old coupe with only 34k miles and it had not yet had Inspection 1 done, so I had that done before taking possession, and then shortly after getting her home, had the belts replaced, battery pro-actively replaced (it was original!), power steering fluid, and brake fluid (had been 3 years plus, should be done every 2). Tranny & rear end had been done recently enough so I left them. If you don't have documentation for any of that having been done within a reasonable timeframe, I'd get 'em all done. Good luck!
'21 M2 Comp
'19 Golf R |
03-25-2019, 09:32 PM | #14 | |
1692
Rep 685
03-25-2019, 10:13 PM | #15 |
126
Rep 355
changing the oem tranny fluid helped for me,I also did a RE short shifter.Nice ride,enjoy!
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
03-26-2019, 12:01 AM | #16 |
647
Rep 2,051
Congratulations. I'm going to tell you nothing drives like this car, even more expensive sports cars like the 991.1 that I just drove don't capture the raw ragged edge that this car does. The engine with its high redline and wire sharp throttle response thanks to the independent throttle bodies cannot be reproduced especially on modern turbocharged engines. I've driven M2's and the F80 M4 and would never trade this car for either unless I was desperate for back seats and a fixed roof.
As for the 1-2 shift, to be honest I think shifting fast is actually the enemy. Removing the CDV doesn't really help either IMO. You actually have to shift "slow", in other words add an artificial "delay" to releasing the clutch. The real issue as I see it is the gearbox doesn't actually immediately seat properly into 2nd even though it feels like it is. You can't always trust the feel and sound of it to guide you. There's actually a "notchy" clunk feeling normally in this gearbox when you get into second but it can be deceptive because it doesn't always signal the gear is lined up. You almost have to wait for a second, deeper notchy clunk as you put it in before you clutch out. It is hard to describe but for me 100% anytime I grind its because I clutched out too fast for this gearbox after putting in second and each time I felt stupid. Only one time did this approach fail me and I have to admit it was frustrating in that moment because it made me feel like it was hopeless to avoid but it only happened once. I am definitely going to try to Royal Purple oil at some point to see if it helps. Not really an ideal situation if you're trying to break 0-60 records or drag race but for just regular go fast enjoyment it isn't a detractor to shift this way at all IMO. And way to go, now after writing this I miss my car and can't wait for spring to come so I can take her out |
03-26-2019, 12:40 AM | #17 |
My other car is on Mars
636
Rep 3,124
As for the 1-2 shift the CDV delete and clutch stop help, but you have to resign to the fact that the car has a high torque-to-weight ratio.
It's naturally going to be very unforgiving of the slightest rev mismatch. Driven mine for 8 years and 150k miles. I can almost get it right every time, but not every time, especially when cold and on fast idle. I don't grind it, just a little jerky. Same for 3-2 downshift. Very small window to hit between not enough blip and too much blip. Fly-by-wire throttle conspires against you, too. If I'm "on-it" I can hit my upshifts and downshifts 99.9% of the time with perfect rev match. I think that comes from driving a MK1 MR2 for 22 years. That car was under powered and perfectly balanced so I never had to worry about the tail coming around on me. Flogged the snot out of it 100% of the time. Driving with "restraint" in the Z4 is something I had to learn. Is it more fun to drive a slow car fast or a fast car slow? After 8 years jury's still out. MR2 was a hoot.
Warning: May contain traces of nuts.
03-26-2019, 07:34 AM | #18 | |||||||
102
Rep 344
03-26-2019, 09:59 AM | #19 | |
1138
Rep 2,867
Drives: Anything
Make sure to tell them to use Royal Purple Synchromax to smooth out the feel in the stick |
03-26-2019, 12:04 PM | #20 |
your average JAMF
3101
Rep 4,094
The tranny is a compromise, and bit of a turd. They wanted to use the E46 M3 gearbox but it wouldn't fit, so they stuck with the non-M Z4 gearbox. Thankfully it has proven durable, if not ideal, for the application.
'21 M2 Comp
'19 Golf R |
03-26-2019, 12:45 PM | #21 | |
851
Rep 4,057
Congrats on the new ride.
Huz-Z
BMW Z4 3.0si Roadster. Montego Blue Metallic. Premium and Sport Package. |
03-26-2019, 01:13 PM | #22 |
salty cowboys fan
6159
Rep 3,408
Welcome to the club! Really pretty one you got there. My .02c :
-CDV removal made no difference in the 2nd gear shift for me -Stiffer engine & tranny mounts and SSK, while all very good improvements in terms of feel, didn’t really help the 2nd gear shift either -best thing to do is just slow down a hair and use some force. Haven’t been locked out of gear since! Re: valve adjustment, I believe it’s part of both inspection 1 and 2. If you can wrench yourself, it’s not difficult to do. Aftermarket shim kit and tools are reasonably priced and are just as good as OE. Expect to swap rod bearings at some point. Some people are lucky, but it seems for most people it’s a wear item. Better safe than sorry IMO. Oil analysis via Blackstone Labs can help you know how close you are to kaboom. Should check the vanos bolts and hub ASAP. There’s a lot of good info on here you can search. If the hub is in good shape, the Beisan pump disk is an excellent way to make sure it never breaks in the future. It will also remove the engine rattle that comes around ~3k rpm. Cheers and welcome again
she’s home! '22 M4 Comp xDrive
ryank382102.00 |
