ZPOST
  TireRack
      03-05-2019, 07:21 PM   #1
mikestark
Drives: 2005 BMW Z4
Throttle reset question pls
So, i noticed a leak at the disa valve and then there was a small cap to the right of throttle body that was cracked. So, I made new gasket for disa valve and bought a new rubber cap. Fixed the leaks and car is fast than ever. Today, which is 2 days later code p1635 (Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted) and p1632 (throttle adaption not met) pop up.
Now my question is should i have reset the throttle adaptation bc the leaks were fixed and made a tremendous acceleration difference? Since, I did not reset is this why the codes popped up?
      03-05-2019, 10:06 PM   #2
StickMon
My other car is on Mars
StickMon's Avatar
636
Drives: 2006 MR
Possibly. Sounds reasonable. Resetting the adaptations would be my first try.
I would use INPA, but you might not have that.
I'm pretty sure years ago I saw somebody mention an incantation you could do with the gas pedal, like hold it to the floor for 3 seconds after turning the key to On, but not yet starting the engine.
Warning: May contain traces of nuts.
      03-06-2019, 06:07 AM   #3
mikestark
Drives: 2005 BMW Z4
Can i reset with an innova 3100 obd scanner?
zpost
