02-20-2019, 10:20 AM | #1 |
659
Rep 1,118
Clunking noise e90 m3
To begin with, I Just replaced sway bar bushings, front control arms are ok..
Clunking noise over bumps, but goes away when the EDC setting is on sport. Any ideas? Any experience with this? Please help! |
02-20-2019, 10:47 AM | #2 |
1341
Rep 1,881
did you properly preload the sway bar bushings before you tightened down the bushing bracket?
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
02-20-2019, 04:41 PM | #3 |
659
Rep 1,118
The bushings were installed at a very reputable Indy garage, but I will follow up.
I’m wondering about either the EDC shocks themselves, or the shock mounts. It’s very unusual to have the noise disappear under sport plus. The sway bar bushings would make noise either way... |
02-20-2019, 09:19 PM | #4 | |
1688
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
02-21-2019, 06:22 AM | #6 |
659
Rep 1,118
Thx.
I’m leaning towards pulling shocks out, and replacing them as well as with new mounts. Anyway of visually inspecting that EDC shocks are bad? They still function, but I wouldn’t want to replace them if they’re still good. |
03-22-2019, 07:39 PM | #7 | |
241
Rep 387
It turned out to just be my Left Front Lower Ball joint NUT was loose! They tightened it up as well as all the nuts in its vicinity and it completely went away. Anyway, not sure if we had the same issue but I figured i'd that just in case! |
03-23-2019, 07:59 AM | #8 | |
659
Rep 1,118
With the weather warmed up, I’m leaving the car at my Indi for a few days. They’ll sort it all out, and I’ll let you know. |
04-14-2019, 10:37 PM | #14 |
5237
Rep 10,617
Replaced bushings or endlinks? If links, were you using stock or adjustable and were they the correct length for the aftermarket swaybar?
04-15-2019, 07:15 AM | #15 | |
659
Rep 1,118
While the car was supposed to have stage 3 Dinan, I believe over time the previous owner replaced worn parts with different aftermarket or stock. The garage owner took his time with my car this time and the cure was to replace the sway bar with stock. I as tempted to go back to Dinan, but for the driving I do, this will be fine. I am certainly just happy to have the clunk gone! Now, of course, I still have brand new bilsteins b6 EDC... |
04-15-2019, 07:16 AM | #16 |
659
Rep 1,118
