02-12-2019, 12:34 PM | #1 |
Rep 26
thicker tires for f80 saloon
Whats up ladies an Gents.Im looking to go up to 40 instead of the stock 35's on the front and rear,Does anyone know if that's fine or if i'll be rubbing against the wheel wells or not? I live in NYC and them potholes can be killers, I tend to think the 35 is to low profile for these streets.Any insight or advice would be well appreciated.Thanks a ahead of time and look fwd to your replies.
Dave. |
02-12-2019, 12:45 PM | #2 |
1797
Rep 2,997
One of the most common moves is to increase the width of the tire which will simultaneously increase it's height at the same sidewall ratio (i.e. 35).
So, for example, it's common for people with 19" stock wheels to move to 275/35/19 fronts and 295/35/19 rears. This has the effect of increasing the stock sidewall height by ~7mm or about 1/4". And it fits fine stock. And it adds more rubber laterally on the road - which is both a plus and a minus. |
02-12-2019, 03:17 PM | #3 | |
60
Rep 195
02-13-2019, 07:19 AM | #4 | |
Rep 26
02-13-2019, 09:34 AM | #5 |
384
Rep 490
Curious to what the greatest overall diameter tire you can run as well. 275/35/19 fronts = 26.58 and 295/35/19 rear = 27.13 with is about 1/2" larger than stock, 1/4" additional radius as JoeFromPA said.
I had done the same thing with my E39, I ran Michi PSSes a full series up to give almost 1/2" more radius. No fitment issues even slightly lowered on coilovers. It really soaked up crap NJ roads. Edit: Pondering 275/40/18 on an 18x9.5 wheel = 26.7", or maybe as far as 255/45/18 on an 18x9 = 27.0" up front for a cold weather set. Too much up front? Last edited by agentrnge; 02-13-2019 at 09:52 AM.. |
02-13-2019, 09:58 AM | #7 | |
370
Rep 488
IG: @circuithunter
agentrnge383.50 |
02-13-2019, 10:19 AM | #8 |
384
Rep 490
ntgarage44, Circuit Hunter
Thanks for the suggestions and info for alternates over the PSS. I did not plan on running them on the M3. I have Conti EC Sports on the stock 19s as the current summer set. And if I were to replace them it would be something equally grippy, grippier than PSS. Looking for a cold weather ( no snow duty ) set atm, and was probably going with Mich PS AS3+. |
02-13-2019, 11:18 AM | #9 | |
Rep 26
I want to do exactly that 265/40/19 front and 285/40/19.Just wondering why u have the 18? |
02-13-2019, 11:29 AM | #10 |
5023
Rep 6,871
02-13-2019, 11:33 AM | #11 | |
2892
Rep 2,147
That being said, I think 18s suit the M3 much better than the M4. I can see why someone would go with 19s on the M4, but to me the comp pack 20s are gaudy, just not for me. But that's why there's something for everyone. |
SherM4n630.00 |
02-13-2019, 11:38 AM | #12 | |
Rep 26
Can I put 265/40/19 front and 285/40/19 on my m3 and not rub against the wheel well?PLEASE let me know it will be very much appreciated. since I need some all seasons asap.Thanks ahead of time everyone. |
02-13-2019, 11:49 AM | #13 | |
2892
Rep 2,147
Could you? maybe. Should you? No, get some 18s if you want to run 40 profile. |
02-14-2019, 11:25 PM | #14 | |
370
Rep 488
IG: @circuithunter
02-24-2019, 10:48 PM | #17 |
47
Rep 125
The rear wheel gap always bothered me because its noticeably wider than the front tires. This post by CanAutM3 explained and helped me a lot in deciding my next tire size.
https://f80.bimmerpost.com/forums/sh....php?t=1089535 |
11-22-2022, 04:26 AM | #18 |
Rep 2
I've been searching for this too and finally try it myself.
255/40R19 + 275/40/R19 - no rubbing, works very well. You can feel more sidewall movement and car became more comfortable. It is what i've been looking for winter. It works better on snow/icy road. Of course on summer tire it doesn't make much sense but if you try to have some more grip in winter condition it works. (Sorry for pictures quality) |
11-22-2022, 08:07 AM | #19 | |
1105
Rep 927
