12-28-2018, 01:52 PM | #1 |
2362
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Strange behavior at the track
I had some strange behavior at the track where car suddenly judders and loses rear grip.
I'm guessing this is related to malfunctioning abs pump (I have the christmas tree on) and traction control that is supposed to be off somehow kicking in but not sure.. can anyone chime in? It starts at around 4:44. Also happens around 2:50, 3:40~3:50.
Pass me if you can.
12-28-2018, 02:13 PM | #2 |
1919
Rep 1,889
Drives: E92 M3
I didn't watch the whole video but just the spin when entering the track is odd enough that you should have tried to figure out what's going on right away. The track is wet, but doesn't have standing water. Unless your tires are in terrible condition, that shouldn't be an issue at these low speeds. What's the condition of your tires and what are they?
If you have the tire pressure light on and along with some other things, DSC kicking in could be partially responsible for this. Is that the case? Have you tried doing a reset of the TPMS? When switching from 19" street wheels (with TPMS) to my 18" track wheels (without TPMS), I have to reset the sensors or DSC will kick in at very low speeds and the slightest of turns. |
12-28-2018, 02:21 PM | #3 | |
2362
Rep 2,362
What I find strange is that although I've had ABS issues for a while which is supposed to disable traction control completely, it somehow seems to be kicking in randomly. I don't think we have TPMS in Japan. Maybe I'm just ignorant to drive in this condition.
Pass me if you can.
12-28-2018, 02:23 PM | #4 |
491
Rep 197
My initial thought watching this is that you're getting no where near enough speed to get any heat in the tires and with traction control turned off on a wet track, its going to be pretty easy to break the tires loose.
What tires are you running and what is their condition? Edit: You responded as I was typing. R-Comps need heat to get any decent traction. It doesn't look like you were going to get anywhere near fast enough on this track for that. Wet and icy on R-Comps... its going to kick loose at random times. |
bigjae19761571.00 m13s25.50 |
12-28-2018, 02:27 PM | #5 | |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
FuzzyPeaches490.50 |
12-28-2018, 02:29 PM | #6 | |
2362
Rep 2,362
R: RS4 (265/40/18) 29 psi cold Ventus RS4 was initially on front but swapped to rear after one track day at Suzuka. This is the first track day for RE71R (1000km~ mileage.) Both have quite a bit of tread left.
Pass me if you can.
12-28-2018, 02:36 PM | #7 |
491
Rep 197
Ok... Not really what I would call R-compound tires, but what I said earlier still holds true. Granted, my track/race knowledge is e30 based, but I believe those pressures are way too low to start out on a freezing track where your speeds are barely getting you to 3rd gear. Someone with more e9x track work will hopefully give you a good base for that.
12-28-2018, 02:38 PM | #8 | |
2362
Rep 2,362
Pass me if you can.
12-28-2018, 02:43 PM | #9 |
491
Rep 197
Its the same as the other two. Those all have treadwear ratings of 200 (not sure how these work outside of the US). R-comps will have a TW rating of roughly 40.
12-28-2018, 02:58 PM | #10 |
1919
Rep 1,889
Drives: E92 M3
That's not going to work well as you found out and there's really not much to learn with that tire combo and icy conditions. Put on regular street tires and enjoy a day easily drifting around the corners without destroying your tires.
12-28-2018, 11:12 PM | #11 |
1571
Rep 8,076
You'd be surprised how bad cold tires feel. I just got to experience cold and heat cycled tires for the first time last month...almost spun in the pit lane.
12-30-2018, 12:48 AM | #12 | |
2362
Rep 2,362
Which tires were you on? I kind of knew RS4s would crap out at this temperature range because I could casually drift with my 140ps Z3 track car
Pass me if you can.
12-30-2018, 12:54 PM | #13 |
1571
Rep 8,076
[QUOTE=kyrix1st;24171373]Hankook C51s. If the RS4s are like the RS3s then they will perform like shiet under 40 degrees.
12-30-2018, 10:35 PM | #15 |
75
Rep 387
RE71Rs shouldn't be run below 40F.
Mismatched front and rears? That isn't doing you any favors. |
bigjae19761571.00 |
12-30-2018, 10:53 PM | #16 |
11586
Rep 12,728
i have 295 rear tires with solid sub/diff bushings. on wet pavement with mdm on, the amount of tires slip it allows sort of makes this shuttering like the tires are hopping. i think it just might be a trait of tires on wet pavement with traction control.
Instagram; @roastbeefmike
12-31-2018, 11:46 AM | #17 |
1571
Rep 8,076
That can be tricky. I do know NT01s on the front and Toyo RR's in the back are a workable combo.
12-31-2018, 11:48 AM | #18 |
2760
Rep 5,483
It’s called wheel hop. Normal but not desirable obviously
Also, the rS4 and re71r light off very differently in the cold and damp. Re71r comes in much faster than most other tires. That tire combo in those conditions qualifies as a USDA Choice Grade A Bad Decision imo |
admranger2984.50 |
12-31-2018, 12:08 PM | #19 |
85
Rep 330
Were you hitting the gas pedal when it happened? My car does that all the time going from a standing start in rain or even 40% throttle 2nd gear in freezing temp. The solid subframe mount helped a lot but doesn't completely eliminate it. However, I have never got any hopping from the rear during deceleration or corning. The rear typically slides out progressively rather than suddenly transitions from gripping to hopping.
12-31-2018, 01:28 PM | #20 |
203
Rep 699
hmm
Well the sounds at 5:27-5:35 certainly indicate a drivetrain malfunction of some kind; otherwise hard to hear over the bouncy music
With slippery conditions like this I would recommend to aim for a lot smoother steering input, but the malfunction does not seem to be related to your turns. Cool (and safe) that you had the whole track to yourself... |
01-04-2019, 05:28 AM | #21 | ||
2362
Rep 2,362
Interesting should you ask, because on dry, I usually try to follow "brake to the limit, then fully release to distribute grip to all four wheels when steering into a corner" which typically isn't preferrable with under-steery setup on braking as you get relatively more understeer without trail braking. (as weight transfers from front back to rear, getting back to the "understeery" nature.) Video below provides a good explanation by Taniguchi,from 10:00 to 11:00. You can see that the car that is oversteery in nature gets too sideways if you trail brake into a corner. Conclusion in the video is in order to go fast, it's important to make the car more turnable in nature (primarily with aftermarket LSD) rather than resorting to typical braking techniques for understeering vehicles, which most passenger vehicles are. Then again, it's all preference. Quote:
Pass me if you can.
Tags |
abs, dsc, e92 m3, judder, rear grip, track |
