ZPOST
  TireRack
      12-19-2018, 03:01 PM   #1
mziggy16
31
Drives: '07 Z4MC, '01 911 C4 Cabriolet
Console Part ID Help
I'm trying to figure out part #'s for some console parts that I'm planning to replace. I figured out most of them, but there's one particular spot giving me trouble. See the pic.
Here's the Real OEM diagram, which doesn't seem to contain this particular piece of plastic:
https://www.realoem.com/bmw/enUS/sho...diagId=51_4931
Any thoughts?
CURRENT: '07 Z4 M Coupe /// ‘01 911 C4 Cab
SOLD: '06 330i / '07 335i / '07 X5 4.8 / '13 335i
      12-19-2018, 03:32 PM   #2
Roadroach
Roadroach's Avatar
165
Drives: 2006 Z4 3.0si coupe w/stick
That's the "handle recess" #21 in the schematic.
I'm not sure if the center piece (grayed out part #12 in the schematic) is sold with #21 or what.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list)
2015 335i GT
2014 981 Cayman S manual
      12-19-2018, 03:52 PM   #3
Steeler
Steeler's Avatar
2429
Drives: Built not Bought 04 Z4 VF
If it’s the centre arrow, this is the part.
https://www.ecstuning.com/b-genuine-...r/51167026223/
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
SD ///M42992.00
      12-19-2018, 04:30 PM   #4
mziggy16
31
Both of these responses are exactly what I need.
Thank you!
      01-15-2020, 10:04 AM   #5
cbecker33
56
Drives: Z4 M Coupe
Thank you!
mziggy16
Did you end up buying these pieces? I have a few scratches in the 'center console' and it looks like it might be pretty cheap to replace (as opposed to repair). Did you need parts 21, 12 & 9 from the diagram? Any others?
      01-15-2020, 10:32 AM   #6
mziggy16
31
Originally Posted by cbecker33 View Post
mziggy16
Hey Chris - I didn't end up buying them. Mine weren't scratched but just had that old plasticky look to them and I was able to get it back to more of a matte finish with a handful of different interior trim products.
I can attest that pulling those plastic trim pieces, sanding and painting is a complete PITA. I did that for my steering wheel trim and it took forever to re-glue broken pieces, sand them and re-paint.
I believe the pieces that you need are accurate based on that diagram: 21, 12, 9. Plugging the PN's into ECS usually gives a better visual to confirm.
-Mike
      01-15-2020, 01:49 PM   #7
rsutoratosu
114
Drives: Z4 3.0i
I'm in the process of pulling out all the parts.. im on beige and changing to black. some parts is PITA to refinish in black, ash tray area I order used, should clean up okay.. rest should be easy enough to pull and sand.. im doing piece by piece lol
-Roranji
      01-20-2020, 02:31 PM   #8
cbecker33
56
Drives: Z4 M Coupe
Thanks!
      03-10-2020, 09:19 AM   #9
cbecker33
56
Drives: Z4 M Coupe
Correct part for black is: https://www.ecstuning.com/b-genuine-...r/51167158485/
zpost
