12-02-2018, 10:53 AM | #1 |
Rep 12
Bilstein clubsport adjustments - Coach a Noob
I am putting on a set of bilstein clubsport for the car next week.
Got a second hand set real cheap off another M3 owner and sent it off to bilstein to get it refurbished. Their turn-around was real quick, aside from waiting for the top mount bearings which took awhile to source, the actual work took only about 3 days all in all. Shocks are in their own words "as good as new" right now. I have previously used B16s which are single adjustment and they were an awesome set of coilovers. The clubsport I understand have independent rebound and compression adjustment. 2 questions I have on the incoming "new" coilovers 1) What are the recommended settings you will go for normal daily drive use? Compliant enough for the "performance luxury" category the car is supposed to fall into 2) Any rules on tailoring the individual settings for particular conditions? I.E under what situation do you drive up compression / rebound and vice versa Thanks for any help! |
12-04-2018, 08:00 PM | #2 |
Admiral
933
Rep 3,886
Here's my go-to reference for rebound and compression adjustments. Start in the middle and work from there!
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
01-04-2019, 06:21 PM | #3 |
90
Rep 363
I'm also curious about this. How easy is to to physically adjust all settings when I'm switching back to DD wheels? I believe the compression and rebound and in different places front and back? Will I have to cut the trunk liner to adjust the rear?
Thanks, Last edited by MPower7; 01-04-2019 at 06:31 PM.. |
01-09-2019, 01:52 PM | #7 |
Derbo Tuning
3612
Rep 3,027
I have MCS but the concept is the same. I used some 3" OD plastic end caps and used a dremel and random tools to cut open the hole. It is relatively directly below the grommet hole right above the shock tower area.
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
Makaveli7116.50 |
01-09-2019, 01:58 PM | #9 |
Enthusiast
117
Rep 150
I ordered these for the rear
https://www.turnermotorsport.com/p-5...nders-br-type/ @op any pics of the billies??
01-09-2019, 03:28 PM | #10 |
Derbo Tuning
3612
Rep 3,027
Thanks! If I could've found the factory non-EDC caps, that would also be a good option for a cover instead of hard plastic like what I bought. I'm looking for a end cap in rubber like the factory ones since I can't seem to find the part number for the non-EDC ones (I hunted ETK and REALOEM for hours and couldn't find it.) I've been trying to find this piece but may have to go to homedepot for some fun. https://www.m3post.com/forums/showpo...8&postcount=18 Others have done this with extenders too but I don't know if Bilstiens have it.
IG:ruhrohz_m3
01-09-2019, 11:42 PM | #11 |
Latif
265
Rep 378
Here ya go
Instagram: latif_eshaq
