10-13-2018, 09:59 PM | #1 |
3903
Rep 4,169
Wheels Rubbing
I'm on Volk ZE40 19" ET22, 9.5" front with 255/35/19 AD08R tires. Tires run more square than normal.
Noticed today that my front right tire is rubbing against the fender liner at full lock.. There's even a small hole starting to appear (red arrow). Is this normal? I was thinking of adding 5-10mm spacers for a more flush look. Will that help or make it worse? |
10-14-2018, 12:48 AM | #2 |
2741
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Normal and spacers will make it worse
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
10-19-2018, 12:36 AM | #4 |
729
Rep 3,966
To aggressive offset for a 26" tall tire, its the overall diameter with the aggressive offset not the width.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
10-19-2018, 05:05 AM | #5 |
3903
Rep 4,169
10-19-2018, 11:31 PM | #6 |
Save the manuals!
6019
Rep 6,750
He's taking about the taller 255/35/19 tire up front.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
10-23-2018, 04:34 PM | #7 |
BimmerPost Supporting Vendor
1438
Rep 2,650
Redd,
It looks like the front tire you are running is a bit too tall and is the cause of that rubbing. This scrubbing on the liners is normal and will not damage anything other than that liner. You could consider going with a 265/30-19 in order to drop the tire down to a 25.26" rolling diameter which should aid in clearance. A 265 tire also fills out a 9.5" wheel a bit better. Please note that adding a spacer to this fitment up front will make the scrubbing worse and is not recommended. - Max
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 10-23-2018 at 05:57 PM.. |
10-23-2018, 05:57 PM | #8 | |
2741
Rep 6,734
'23 X7
10-23-2018, 06:00 PM | #9 |
1438
Rep 2,650
Correction made. Meant to say 265/30-19. Thanks for catching that
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
slicer2741.00 |
10-23-2018, 06:06 PM | #10 |
2741
Rep 6,734
I figured that. You guys usually give good advice
'23 X7
10-23-2018, 06:09 PM | #11 |
1438
Rep 2,650
10-23-2018, 10:43 PM | #12 | |
3903
Rep 4,169
10-24-2018, 12:18 AM | #13 |
503
Rep 1,055
I had the same tires with an et 25 9.5" wheel. Also rubbed on full lock. I dealt with it by not making full lock turns.
I'm now on 275/30 on 10" wheels which also rub and deal with it the same way. More work to complete tight turns, not ideal but comes with the territory. |
10-24-2018, 06:36 PM | #14 |
3903
Rep 4,169
I wonder if this Turner Rackstop kit will help:
https://www.ecstuning.com/b-turner-m...it/tsu9090001/ |
