10-10-2018, 07:05 PM | #1 |
Rep 12
E92 Rotor Max/Min Specs
Short story: BMW dealer says "your '12 E92 pads are fine at 38k, but your rotors are near the minimum spec. But it passes PA state inspection." They did not provide any details on the rotors depth/specs. Yes I did ask. This just doesn't sound right to me.
Back story: I bought the car in '13 at 7k. No brakes/rotors were changed between 7k and 38k (aka while I owned it). I have performed fluid changes at prescribed intervals. I have no indication that the prior owner did anything crazy (track days or otherwise) with the car. So @ 38k I BELIEVE it's on OEM ORIGINAL pads and rotors. ** Yes this does contradict the BMW dealers statements. ** I will be switching from summer to winter tires shortly. I want to measure the rotors and truly understand if the rotors are toast. I have no problem replacing them, but replacing rotors before pads during normal road driving seems strange. (aka no track days, or crazy start/stops) What is the brand-new stock rotor thickness? And what is the minimum thickness? !! Sorry I will not be calling the dealer out. So please don't ask. In the past they have been pretty good to me. I have a local exotic mech that will do the brake and/or rotor work, but I really don't want to waste their time if it's not worth it. I did search a couple of OEM parts dealers but they don't list dimensions. TIA John |
10-10-2018, 08:13 PM | #2 |
197
Rep 573
OEM BMW rotors have the min thickness engraved into the hat of the rotor.
I think these values are right, Front: 30 mm new 28.4 mm minimum Rear: 24.0 mm new 22.4 mm minimum |
10-11-2018, 11:38 AM | #4 |
5269
Rep 10,664
My original rotors were done at about 90k miles. Might have been even more than done. Mostly highway. City driving should use up rotors in fewer miles.
10-11-2018, 03:59 PM | #5 |
3552
Rep 2,824
With street driving I regularly read lifespans of 70k+.
I had a PPI on my car performed at EAS at 47K and they said the brakes were great. During the recent rod bearing work (at 49K), my mechanic said the rotors are near their end with a big lip on the backside. I'm in the same boat as you. Will get a third opinion then figure out what to do. Chapped, putting a lot into maintenance right now and wasn't planning on brakes. |
10-12-2018, 07:16 PM | #7 |
264
Rep 769
10-14-2018, 04:52 PM | #8 |
Rep 12
Kiswether: Your dimensions were correct for my car per the hat engraving.
aswy6: This is kind of correct (at least for me). The rotor has a lip, so adding pair of nickels between the caliper teeth is tricky, but I'm sure it can be done. So with the front min being 28.4mm, I'm getting readings of 28.6x towards the outside and 29.0 in the middle of the rotor. Being conservative, it looks like I'm fine for another 5k (38k/1.4*1.6). Again thanks all! |
aswy6264.00 |
10-15-2018, 03:02 PM | #9 |
687
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Yup, you should be good for a while.
Rotors and pads are really not hard to do on this car if you want to save some $ when it's time to swap them. OEM rotors from FCP are ~$240/each and you get lifetime replacement included.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
