10-06-2018, 03:21 PM | #1 |
68
Rep 192
Paint flaking underneath edge of trunk lid
Just noticed some paint flaking from the edge of the trunk lid. See pics -
View post on imgur.com Overall paint condition is perfect, and fortunately it seems to be isolated to this area. Any ideas as to what caused this? botched repaint, age, heat damage? The car is an 08 from AZ. |
10-10-2018, 02:30 PM | #2 |
1341
Rep 1,881
this is usually a sign of a poor quality repaint. They didnt take the time to properly prep the edge of the trunk, so the paint is failing and lifting. have seen this many times in my line of work.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
NoHedge67.50 |
10-10-2018, 02:58 PM | #3 |
General
63921
Rep 24,820
Your picture shows a bad repaint from the past...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
NoHedge67.50 |
10-11-2018, 08:11 PM | #4 | |
68
Rep 192
I looked another AW e92 which also had similar cracking on that raised area which the owner attributed to it being a "weld" point.. Could a pressure washer cause this? The paint was fine over a year ago - View post on imgur.com Edit - Likely cause is the pressure washer. I inspected the trunk and there's only peeling at areas where the water makes direct contact. View post on imgur.com - my buddy's AW M3 exhibited similar micro cracks as on the sides of my trunk.Last edited by NoHedge; 10-23-2018 at 05:59 PM.. |
10-11-2018, 08:16 PM | #5 |
68
Rep 192
There's nothing on the carfax/autocheck but we all know how reliable they are Found some pics from a year and a half ago and it doesn't look like it was flaking then.. View post on imgur.com Last edited by NoHedge; 10-11-2018 at 08:46 PM.. |
///M Power-Belgium63921.00 |
10-12-2018, 10:28 AM | #6 | |
General
63921
Rep 24,820
Maybe your car was involved in a minor accident , and it was (bad) repainted by a friend or an acquaintance . And so the whole situation came never on paper , and not reported to carfax . Personal I think your trunk is a case of hidden defects...
NoHedge67.50 |
11-19-2018, 05:38 PM | #8 |
68
Rep 192
11-19-2018, 05:47 PM | #9 |
1341
Rep 1,881
i have seen pressure washers do terrible things to paint... i NEVER use pressure washers on my personal vehicles. All it takes is 1 paint chip, and the pressure washer can blow off huge flakes of paint because that little rock chip allowed the pressurized water to get under the basecoat...
NoHedge67.50 |
11-21-2018, 06:51 AM | #10 |
11586
Rep 12,730
if you get too close with a pressure washer, it can happen. lots of people use them without issue. the water pressure isn't a substitute for scrubbing off etched in contaminants... don't get close.
Instagram; @roastbeefmike
NoHedge67.50 |
11-22-2018, 10:18 AM | #11 |
4482
Rep 7,120
OP, nothing to do with the cracking paint but noticed you don't seem to have a rubber sealing at the bottom of your rear window, fell off?
Seems like Monday spray when the paint comes off. Always been using high pressure water on y cars incl the M3 since years, never had any issue. IMO the pain should certainly handle some water! |
NoHedge67.50 |
11-22-2018, 07:36 PM | #12 | |
68
Rep 192
I'm guessing they were standard for all MYs? |
11-23-2018, 04:10 AM | #13 |
4482
Rep 7,120
11-23-2018, 04:58 AM | #14 |
Enthusiast
117
Rep 150
E92s don't have any seal for the lower part of the rear window.
http://www.realoem.com/bmw/enUS/show...diagId=51_6087 The E90s do have them though - Retrofit ? http://www.realoem.com/bmw/enUS/show...diagId=51_5644 You are probably better off going to good paint shop to see if they can touch it up in a way, so it doesn't run to the exterior, and probably so it doesn't give you any rust issues (not sure if the trunk is steel and not alu.) |
NoHedge67.50 |
11-23-2018, 03:01 PM | #16 | |
68
Rep 192
I've scraped off the flaking and will apply some touch up. The underside of the trunk seems to be coated so should be okay for now as the flaking is isolated to the raised edge. |
Makaveli7116.50 |
