09-20-2018, 04:27 PM | #1 |
59
Rep 61
Tires recommended to wheels 18x8
Hi guys, I'm confused about to choose a correct tires size, I need to replace the 4 tires, my car have 18x8 (4 wheels) currently I'm using 225/40R18 tires, I would like a staggered setup, I was thinking 235/40 front and 245/40 rear, can you give me your opinions?
09-21-2018, 08:49 AM | #2 |
425
Rep 545
The fronts should be fine, but may rub a little depending on your wheel offset. For the rears, it's better to go with 245/35 as it's closer to the OEM diameter
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
2Veloce59.00 |
09-21-2018, 01:15 PM | #3 |
59
Rep 61
I think that maybe do not fits 245
09-21-2018, 03:27 PM | #4 |
425
Rep 545
What offset are your wheels? Our cars need a pretty high offset in the rear, usually around 45-50 which can be hard to find.
09-21-2018, 04:23 PM | #5 |
59
Rep 61
09-21-2018, 09:23 PM | #6 |
545
Rep 1,233
That is quite aggressive, a 245 will rub on large bumps most likely. They will physically fit on the rim, but the rubbing is the issue.
As a comparison, the stock rear offset with 18x8.5" wheels is 52...your wheels are a lot more aggressive than that so you may need to stick with 225 especially if the car is lowered at any point. |
09-21-2018, 11:47 PM | #7 | |
59
Rep 61
09-22-2018, 05:36 AM | #8 |
C2H5OH
3920
Rep 2,145
First, that is the most awkward angle on that wheel. It looks to be missing spokes.
Second, why would you want to stagger tire widths? There is zero benefit in it. |
09-22-2018, 05:41 AM | #9 |
1545
Rep 3,071
According to the Apex Race Parts site you can fit 18x8.5" ET45 with 235/40-18 tires on all 4 wheels with stock suspension. (5mm spacer needed for some aftermarket suspension)
Comparing that to an 8 inch wheel using the offset calculator at 1010tires.com https://www.1010tires.com/Tools/Whee...et-Calculator# The 18x8 et 35 will have 16mm more inner clearance and extend out an extra 4mm. Which looking at the picture might be what you have. If so the 235/40R18 should fit. I thought about running that set up but I have a 135 and didn't want to downsize the rear tires. As noted above running a square set up is better for tire life, wear & handling. Staggered is for looks or if you need more rear grip. With an et35 wheel though the 245 is probably too wide. The 235/40 should be ok and hopefully won't rub on the outter fender. Are you sure they are 18" wheels? The M2 style wheels are 19"?
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
2Veloce59.00 |
09-22-2018, 12:15 PM | #10 |
59
Rep 61
09-22-2018, 12:29 PM | #11 | |
59
Rep 61
09-22-2018, 12:56 PM | #13 |
1545
Rep 3,071
My best guess you could fit 235/40 front & 245/40 rear, but to be honest the 245s are only 0.3" wider (0.762 cm). Personally I'd go 235/40 square to be able to rotate them.
https://m.tirerack.com/tires/Spec.js...re=44YR8PS4SXL
2Veloce59.00 |
09-27-2018, 06:04 PM | #14 |
59
Rep 61
Finally I bought 225/40 Front and 235/40 Rear
Zombie_Head594.00 Setright22.00 |
10-16-2018, 02:05 PM | #16 |
59
Rep 61
10-19-2018, 12:16 AM | #17 |
20
Rep 83
