06-12-2018, 01:31 PM | #1 |
3221
Rep 6,218
Track guys...BE or WPC?
I know this topic has been destroyed to seat in the other thread. I just want to know which ones you guys have personally went with. Don't really spend time in the other sections of the forum.
06-12-2018, 01:37 PM | #2 |
Stop the hate, get a V8
3850
Rep 8,625
Interesting question as it relates to track usage. Subscribed.
Past: 2011.5 M3 sedan ZCP |
06-12-2018, 01:39 PM | #4 |
239
Rep 170
I used BE bearings and BE ARP rodbolts. 2 track days so far. Service interval for going in and looking/replacing them is on my list of things to think about. I put a lot of street miles on the car, so that factors in as well. But maybe two years or something.
2012 E92 M3 ZCP MCS 2WR coilovers 600F/900R, Performance Friction ZF54 front BBK, stainless lines, Ferodo DS 2500 rear pads, Hotchkins F/R swaybars, solid subframe mounts, BE Bearings, ARP rod bolts, Bimmerworld motor mounts, AFe intake, underdrive, CSF radiator, GT4 front lip (ebay), APR GT 500, ebay side skirts, RaceEng tug, 15mm/10mm spacers on ZCP wheels, Apex ARC 8 18x10 square track wheels with Pirelli 265 DH slicks
06-12-2018, 02:12 PM | #5 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
I went BE based on feedback from other track junkies. I just had it done and haven't been to the track with this car yet.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
06-12-2018, 03:01 PM | #7 | |
3221
Rep 6,218
06-12-2018, 03:07 PM | #8 | |
///M Powered for Life
11490
Rep 10,329
I have BE bearings and BE-ARP bolts on both track M3s. I don't see any good reason to do differently |
DrFerry6728.50 |
06-12-2018, 03:15 PM | #9 |
3850
Rep 8,625
Aren't several of these bearings just made by the same company anyways, and it's just a matter of rebranding or additional tweaks being done?
06-12-2018, 04:39 PM | #10 | |
11490
Rep 10,329
WPC are OEM bearings made by Clevite (not sure of the tin/alu ones were but I believe the originals were). These slightly increase clearance and were a good option back when there were no specific increased clearance bearings VAC are made by Clevite to the 'VAC spec'. I shuddered a bit writing that. VAC has changed their tune several times as to what exactly this bearing is, but currently they say it's increased clearance. BE bearings are made by Clevite as well. BE has all the info published right here and their spec is different than the rest. They're the only ones who have 'industry standard' clearance. In terms of clearance there's OEM<OEM+WPC<VAC<BE |
06-12-2018, 04:47 PM | #11 |
1889
Rep 5,506
VAC adds their own coating to the bearings which makes it close to OEM spec... doesn't really increase clearance.
Still way better than WPC - VAC uses softer lead/copper bearings so should they wear, it won't be as bad as the treated OEM hard aluminum bearings that WPC has. BE Bearings are the only ones that actually increases clearance.
Auto Detailing Enthusiast!
06-12-2018, 04:51 PM | #12 |
47
Rep 115
06-12-2018, 10:15 PM | #13 | |
3221
Rep 6,218
06-12-2018, 10:21 PM | #14 |
5234
Rep 10,616
Plus there are ACL. Many racers of older BMW use ACL bearings. I don’t think you can go wrong with any of them. The biggest risk is leaving your original bearings in the motor.
06-12-2018, 10:31 PM | #15 |
BimmerPost Supporting Vendor
731
Rep 3,735
Go with either VAC or BE. WPC is inferior to both as it is retaining the same bi-metal (tin/aluminum construction) with minimal clearance gain.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
06-12-2018, 11:38 PM | #17 |
3221
Rep 6,218
ordered BE earlier in the day. Thanks guys!
06-13-2018, 08:34 AM | #18 |
3850
Rep 8,625
I assume those are also made by Clevite?
06-13-2018, 09:07 AM | #19 |
506
Rep 1,385
Previously vac was coating factory bearings and selling them in the replacement kit. Vac now uses the same Clevite 77 bearing that BE does, vac come with coating as well the BE do not. I've installed both now about 10 times and have yet to see a complaint from any one after the job was complete. What I did notice is the tq specs are different I've see some call for 50lbs while others have called for 45 from vac. just my .02 it doesn't matter which you choose they both offer better clearance then stock.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
so0fresh46.50 |
06-13-2018, 09:08 AM | #20 |
506
Rep 1,385
ACL is a separate company. the three main bearing companies I've seen are
clevite King and ACL.
06-13-2018, 09:09 AM | #21 | |
11490
Rep 10,329
06-13-2018, 09:10 AM | #22 |
11490
Rep 10,329
ACL appears to be another company. It's clearance seems to be the same as the VAC ones, so more than stock but not as much as 'industry standard' which is BE
