XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      06-12-2018, 10:52 AM   #1
HBWT
HBWT's Avatar
Drives: 2013 X1X 2.8
My X1 experience...
Ordered my X1 2.8 xdrive Mineral White with Ultimate, MSport, Lighting Pkg, Heated Seats, Sat Radio, HK, in early October of 2012 and took delivery in late Nov 2012. Added roof rails, rubber mats, Execuhitch, Tint, and Burger Stage 1.
Drove for 80K and recently traded it on a 2017 VW Tiguan SEL. Disappointingly, the trade in value ranged anywhere from $10,500-14,000 depending on what site. Ended up getting 2 offers...one $12,300 and the other $13,000. I took the latter from the VW dealer.
I enjoyed my X1 but kept it longer than I should have, I think. During my time with it the list of issues was moderate. First issue was with the outdated NAV database at delivery. Selling dealer would update the NAV (at a considerable cost to me) to a release that was available 3 months before I took delivery! Went to another dealer(Checkered Flag) and they updated for free without question. Needless to say I never returned to the selling dealer(Casey BMW) for any type of work. FWIW, I shopped my X1 as spec'd and Casey was $1800 lower in terms of agreeable selling price.
Next issue was a warranty problem related to squeaking dash around the radio trim. Dealer removed the trim and lubed the points where dis-similar plastics were touching. This actually worked quite well and I never had another problem with it.
The Intake Camshaft Spring recall was performed, then the lower steering shaft was replaced and after a ridiculously long wait, the air bags...all under waranty.
Two sets of rear brakes and one set of fronts were installed. I did the last set of rears myself.
By this time the warranty was up and I was beginning to feel the play in the steering shaft again. I let it go and never did correct it. The sunroof shade would occasionally get cranky but re-initializing would always get it back on track. The passenger side-view mirror became an issue...working when it wanted to...usually not working on rainy days...eventually not working at all. Then the Comfort Access stopped working on the passenger side and eventually stopped at all points. The battery was showing signs of weakening so I replaced it at 75K.
Overall, I thoroughly enjoyed my X1. It rode well enough for a small car, it was quick(thanks to the Burger Tune)and it never failed to start and get me where I was going...well there was that one time I shredded a tire. I used it as my DD for 4 years and then gave it to my wife. She liked it but didn't love it, always reminding me how small it was. I will admit that it was small but when we went on trips I used a Cargo box on top and if needed, pulled a small utility trailer. It was barely enough on several of those trips. She recently got herself an F-150 Super Crew 4x4 3.5 Ecoboost so she's happy now...and it will tow the new boat. The X1 would not have towed a 22' Outrage.
So I'm back out of a BMW once again and I'm not sure I'll be back any time soon, if at all. I like the Tiguan and I got it with a 6yr 72K VW warranty...so it will be at least that long. I hope everyone's X1 performs at least as good as this one...it was a work horse. Be well!
      06-12-2018, 01:05 PM   #2
mreric
13
Drives: 2015 BMW X1
I have been thinking of using my X1 for some towing. did you find a good way to pass the trailer wire our from the trunk? most cars have some kind of a pass-through hole. some how i cannot find one on the X1.
      06-12-2018, 05:18 PM   #3
Lucky13
Lucky13
212
Drives: 2014 M235 manual, 2020 X3 30X
Your X1 was identical to our 2013 Mineral White M Sport, were only at 45K and other than oil changes and air bag recall its never been in the shop ( one other recall but I think it was vacuum hose). I’m still on original brakes with plenty and of pad left but my wife drives pretty conservative. Back seat is small but we like small vehicles since we had a Clubman before the X1. Good luck with your new SUV.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      06-12-2018, 06:07 PM   #4
dingo ate my baby
dingo ate my baby's Avatar
Australia
Drives: X1 20D Xdrive
That setup looked cool.
Good luck with the VW
      06-12-2018, 08:27 PM   #5
HBWT
HBWT's Avatar
To install an Execuhitch the bumper must be removed/replaced so while that was off I ran the wiring through the same grommet being used by the PDC sensors. It was a tight squeeze but worked just fine.
Had I not been able to do that I was prepared to drill a hole, prime and paint the bare metal, and insert a proper size grommet. That would not have been a problem. Second to the tune, the Hitch was my most appreciated add-on.
      06-14-2018, 06:50 PM   #6
mreric
13
Drives: 2015 BMW X1
thanks !!!
i will look again, i am installing a curt hitch, it does not require the bumper to be removed only the trim where the sensor are located. i am hoping i will have enough access to pass the wires
      06-20-2018, 11:02 PM   #7
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
Thanks for sharing OP!
Towing is going to be the reason I move away from X1 next year when the lease is up.
Need something to tow my Miata to the track
      06-25-2018, 03:18 PM   #8
phenley
Drives: Alpine White 2013 X1 XDrive
Good Luck on your new ride. I just purchased a 2103 X1 XDrive with 32,000 miles.
My first BMW. So far, So good
