06-04-2018, 03:14 PM | #1 |
1919
Rep 1,889
Drives: E92 M3
Extended Brake Pedals?
I brake with my left foot and the tiny pedal on the DCT makes it difficult for me to step on it smoothly with my wider than normal feet. I found the "GSPerformance P7 Generation III SMG brake pedal" ( http://www.bimmerfest.com/forums/sho...d.php?t=384727 ) which looks perfect, but that went nowhere. Is there a similar option for the E9x?
06-04-2018, 03:34 PM | #2 | |
General
63393
Rep 24,680
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
CorruptCommie345.50 |
06-05-2018, 11:35 AM | #3 | |
Stop the hate, get a V8
3851
Rep 8,625
You may want to browse the BMW Motorsport catalog for the E92 and see if they have something.
Past: 2011.5 M3 sedan ZCP |
06-16-2018, 12:38 AM | #4 |
1919
Rep 1,889
Drives: E92 M3
No luck on the Motorsport catalog or the usual vendor sites. I'll reach out to one of them directly to see if they have ideas.
06-16-2018, 12:43 AM | #5 |
3900
Rep 4,165
Can't you just buy a brake pedal cover for an auto (it's wider than the DCT's which is the same size as a manual's brake pedal) and screw it on?
06-16-2018, 12:56 AM | #6 |
40
Rep 117
I was looking for a similar product as you last year. I asked around and got no luck. In the end, I bought a used auto pedal assembly and swapped the whole thing out. Took me about 30 mins to do as it was only held on by a couple bolts.
You cannot buy a regular auto pedal cover as it's only a slip on cover and has no structural strength. I've alsso teased the idea of welding on a plate of sorts (with bracing) to extend the pedal also. |
06-16-2018, 02:53 AM | #7 |
3900
Rep 4,165
I mean get the aluminum pedal covers like Pedal Haus sells, but buy the automatic set (larger brake) vs the DCT set (smaller brake).
06-16-2018, 07:15 AM | #8 |
1563
Rep 2,869
06-16-2018, 03:10 PM | #10 | |
1919
Rep 1,889
Drives: E92 M3
06-17-2018, 01:25 AM | #11 | |
40
Rep 117
This should tide me over until someone comes out with a better product. Can't complain at $30 for a used pedal assembly. If I remember correctly, it's the same part number as a regular 3 series and maybe some other Exx cars. |
06-17-2018, 06:04 AM | #12 |
746
Rep 1,848
The way the old SMG pedal extension worked was by adding a dummy clutch pedal that provided a bridge between it and the brake pedal. I believe the same can be done with DCT. See link below. Just add the clutch pedal and make a plate or something to tie the two together.
http://www.realoem.com/bmw/enUS/show...diagId=35_0307 |
06-17-2018, 06:04 PM | #13 |
73
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
Turner sells a beefed up brake pedal used on the GT4 cars and comes from BMW motorsport.
https://www.turnermotorsport.com/p-2...d-brake-pedal/ Was thinking of getting this but not sure how much of a difference it would make and its a bit pricey. Edit: just noticed Turner does not have them available anymore |
07-16-2020, 08:26 PM | #14 |
1563
Rep 2,869
I just did my first track day after ACM installed the Auto brake pedal I got on eBay. It felt great not reaching all the way over, but more importantly, it is much easier to trail brake since now I can encore my heel on the floor and ease off the brakes in a controllable way.
Ximian1919.00 |
