05-28-2018, 07:01 PM | #1 |
1919
Rep 1,889
Drives: E92 M3
Zinc Coated Rotors
A year ago I bought some Zimmermann zinc coated rotors and I found them just in time to install them for an upcoming HPDE weekend.
I also got the idea of installing brand new PFC 08 pads so they can be burnished easier. However, on the post-install test drive, I noticed quite a bit of noise (not the usual squealing) and a vibration throughout the car. So what's happening is the zinc coating is being removed with small chunks collecting around the brake pads and inside the rotor holes. I plan on scraping those chunks off so it doesn't collect more. Should I keep braking lightly to moderately to remove the coating before the recommended burnishing process or should I try something else? |
05-29-2018, 10:12 AM | #2 |
winner of many hpde trophies
47
Rep 120
I put new track-compound pads on new zimmermans and bedded them in on the warm up lap. worked just as good as my old worn-in braking setup and the chunks or something? you describe are still on the leading edge of the pad, but they work fine so I don't care.
I wouldn't worry too much about it, time will take care of it. |
05-29-2018, 10:22 AM | #3 |
1919
Rep 1,889
Drives: E92 M3
You didn't get any vibrations while the zinc was scraped off by the pads? That's the only concern I have as braking feels fine overall.
05-29-2018, 10:30 AM | #4 |
47
Rep 120
Only vibrations I got were typical pad deposit stuff on the first lap of some sessions and it was always gone by the 2nd lap and not there on the drive home.
05-29-2018, 10:52 AM | #5 |
Stop the hate, get a V8
3851
Rep 8,625
Curious why you bought the coated rotors if you are going to be using these on the track.
Past: 2011.5 M3 sedan ZCP |
05-29-2018, 11:20 AM | #6 |
1919
Rep 1,889
Drives: E92 M3
These aren't meant to be dedicated for track, just a regular rotor replacement when I originally purchased them. I only do 2-3 track days a year so the stock rotors work fine for me.
05-29-2018, 08:45 PM | #8 | |
47
Rep 120
Quit worrying and drive em. Then, if you bought from FCP, enjoy your free replacements |
