05-20-2018, 01:57 PM | #1 |
225
Rep 489
Texas Inspection questions
I will be registering my F80 in Texas and i have a question regarding the inspection.
Since i am throwing a CEL due to no secondary CAT, would i pass? Do they check for that? Sniff? EDIT. i have my secondary Cats.. but aftermarket DP's.
2020 M2C.
05-20-2018, 01:58 PM | #2 |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
No
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
05-20-2018, 02:00 PM | #3 | |
82
Rep 96
Sandro. |
05-20-2018, 02:04 PM | #4 | |
225
Rep 489
Im wondering if i just do a battery reset it for a day or however long it stays off, if that would work. EDIT: Correction, i have stock secondaries. Aftermarket DP's.
2020 M2C.
05-20-2018, 02:22 PM | #6 |
10785
Rep 8,852
Yes, they sniff in 17 counties.
https://www.dps.texas.gov/rsd/vi/ Items of Inspection for a Passenger Car 05.01 Inspect Every Passenger Car For: (Listed in suggested order of inspection) * Check for evidence of Financial Responsibility 1. Horn 2. Windshield Wipers 3. Mirror 4. Steering 5. Seat Belts 6. Brakes (system) (Parking - beginning with 1960 models) 7. Tires 8. Wheel Assembly 9. Exhaust System 10. Exhaust Emission System (beginning with 1968 models) 11. Beam Indicator (beginning with 1948 models) 12. Tail Lamps (2); (1) if 1959 model or earlier 13. Stop Lamps (3) 1986 and newer; (2) if 1960-1985; (1) if 1959 model or earlier 14. License Plate Lamp (1) 15. Rear Red Reflectors (2) 16. Turn Signal Lamps (beginning with 1960 models) 17. Head Lamps (2) 18. Motor, Serial, or Vehicle Identification Number 19. Gas caps on vehicles 2-24 model years old 20. Window Tint. NOTE: When a vehicle is presented for inspection and the vehicle is from a designated emissions county and is subject to the Texas Vehicle Emissions Inspection and Maintenance Program an Affidavit (VIE-12) is required. (See Chapter 5, page 5-14.)
05-20-2018, 03:22 PM | #7 |
357
Rep 409
Counties requiring emission tests:
Brazoria, Collin, Dallas, Denton, Ellis, El Paso, Fort Bend, Galveston, Harris, Johnson, Kaufman, Montgomery, Parker, Rockwall, Tarrant, Travis and Williamson |
SakhirM410784.50 Vectors2final1356.50 |
05-21-2018, 08:16 AM | #8 |
110
Rep 216
Just get your car tuned 1st, and it'll get rid of your CEL. I've had inspections done with test pipes in my previous car, and I don't recall any shops doing sniff tests. I think as long as your car doesn't exhibit a CEL and when they scan OBD2 with < 2 error codes they pass you. (e.g. Catalyst = not ready = 1 error due to suppression of sensor for no CEL light)
2015 Black Sapphire F82 M4: Bootmod3 Stage 1 Tune / GTS DCT TCU DIFF Flash / Remus Catback / VRSF Charge & J Pipe / MST Intakes / Mishimoto TMIC / RK Autowerks Crank Hub / Apex VS-5RS 19x9.5 ET22 19x10.5 ET45 / Powerflex Bushings / MSS HAS / Evolve x Bilstein B6 Damptronic / Vorshlag Camber Plates / Hotchkis Sways
