04-30-2018, 12:51 PM | #1 |
2432
Rep 11,667
Front compression control arm rubbing
Hey guys, just got the car out for the first track session up here this year.
I have just installed MCS suspension on the car and running 18x10 et25 wheels. I'm running into a rubbing issue on the front compression control arm It only happens when the wheel is turned in. The wheel rim rubs on the arm I'm using a 5mm spacer and clear the strut spring/perch no problem. I tried a 12mm spacer but it still rubs. I'm running max castor on Vorshlag plates to get as much dynamic camber as I can, & I think that may be the cause. Static camber is -2.6 I'm sure this isn't something new to you guys and wondering what you've done about it. I think more neg camber would change the angle and give more clearance but i'm close to the limit w/o opening up the tower hole a bit. (which I'm reluctant to do) raising the car would also change the angle and may provide more clearance as well. I'm 1/2" lower than ZCP spec right now. the other option is to file down the control arm a bit. ...also not great. any and all feedback on the best solution is appreciated.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
04-30-2018, 01:12 PM | #2 |
67
Rep 107
Your tension rods are installed upside down, which looks to be limiting clearance. I have 10.5” +27 up front, which go ~8mm further to the inside, and I still don’t rub at full lock.
inTgr8r2431.50 Chuck's M3162.00 |
04-30-2018, 01:24 PM | #3 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
04-30-2018, 02:58 PM | #4 | ||
2432
Rep 11,667
I had the whole front end off doing rod bearings among other things before track this weekend. LOL... too many midnights in the shop Thanks!!!!!!
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 04-30-2018 at 03:06 PM.. |
04-30-2018, 03:03 PM | #5 |
5355
Rep 2,806
btw, I don't think it's just mounted upside down. Looking at the comparison of the two pics, I think it's mounted to the wrong spot too, which means other stuff is being affected as well. Better get under there and inspect what's going under that car.
inTgr8r2431.50 |
04-30-2018, 03:22 PM | #7 | |
2432
Rep 11,667
I'm always tweaking things.
04-30-2018, 03:32 PM | #8 | |
2432
Rep 11,667
My pic is from the right side suspension and looking from the front towards the rear. It just looks weird
04-30-2018, 03:37 PM | #9 | |
5355
Rep 2,806
Let's put it this way, if you flip that arm upside down, I don't think you will be able to mount it to the same place. |
