XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      04-25-2018, 07:58 PM   #1
safety6
Drives: X1
Radiator crack
I have a 2013 X1 and had to replace the radiator at 72K, anyone else having issues with their radiator. Seems pretty early for a replacement! Sorry should have added more details, my X-1 is a 28i X-drive, I have never used Eco Pro... most of my driving is around town and when I do go on a trip a space out and forget about using EcoPro… I drive my car moderately hard and it's had one track day in its life.. I do not know where the leak was as I had them just replace it when they reported it to me. I knew there was a problem since I have had to add anti-freeze for the last few months. Of course the warranty was up so it was all out of pocket $450 for the radiator and another $400 for the install... that apparently took less than 2 hours... I like the car just hope this is a one off problem as I'd really like to hang on to it for another few years. Looking at some of your replies it looks like there are a few of us out here!
      04-26-2018, 08:36 AM   #2
interceptor428
29
Drives: 2013 x1 28i/2015 428 m sport
I have 112k US miles on mine and radiator seems fine. Where did the radiator crack?
      04-26-2018, 10:29 AM   #3
LevinBR
40
Drives: 2013 BMW X1 xDrive 35i
28i or 35i ?
      04-26-2018, 10:49 AM   #4
0w40X1
34
Drives: 2014 BMW X1 s28i M Sport
Do you use ASS or Eco - Pro?
      04-26-2018, 10:11 PM   #5
Westies
17
Drives: 2013 X1 35i M sport
Mine had a slow leak, just had it replaced a few months ago at 50k miles.
2013 MG X1 x35i M Sport
      04-27-2018, 08:38 AM   #6
SharpAndCunning
100
Drives: 2014 X1 35i
Warranty or out of pocket?
      04-27-2018, 09:26 PM   #7
Mtpisgah
14
Drives: 2010 WRX & 2013 X1
I have had white smoke coming out of the exhaust for a month so it went to the shop. Small coolant leak in the head apparently but the real issue is a cracked radiator at 105k miles. It gets replaced in two weeks at my expense.
2013 28i xdrive
      04-30-2018, 10:51 PM   #8
Westies
17
Warranty, fortunately.
      05-01-2018, 08:54 AM   #9
RoWoX3M
401
Drives: 2020 X3M
My radiator and coolant tank were recently replaced at 55k miles under CPO warranty. I had to pay the dealer $50 for some pressure tests. I noticed my coolant tank was leaking and when they did the test it showed the radiator also had a leak.
      05-01-2018, 02:47 PM   #10
daytona90t
Drives: 2013 X1 35i M-Sport
Interesting post, as my coolant tank just popped yesterday on my way to work. 2013 35i with only 52,000 miles. Even my 2004 330i ZHP coolant tank lasted for 10 years and 90,000 miles before it blew apart. And here I was thinking that just maybe BMW had finally learned how to build cooling systems that wouldn't fail pre-maturely.
      04-29-2019, 11:35 AM   #11
Sha-Ka
Drives: X1_X-Drive 28i
just wanted to add to the post since I am also in the process of replacing the Radiator on mine (2012 X1 E84, 213,000 KM). notices coolant low level a few months, after a 2nd top up looked for the leak, and the rad seems to be the issue.
Going to be doing the work myself; hopefully goes smooth with the seals and hose fittings... fingers crossed!
      04-29-2019, 08:32 PM   #12
m1256
31
Drives: 2014 BMW x1 sdrive28l
Lost mine at 48,xxx miles. started as small coolant drops on the intercooler piping. $900.00 dollars later, BMW radiator and coolant flush at the dealer.
      03-19-2022, 11:55 AM   #13
proteus290
proteus290's Avatar
15
Drives: 2014 BMW X1 35I Ultimate
new radiator 35I x1
coolant leak drivers side@86K
seems i have coolant leak above drivers side intercooler all hoses r new show no seepage, have FTP behr mahle OE lifetime guarantee radiator coming from ftp euro tomorrow.
replaced expansion tank and 1 preformed overflow lower tank hose also .
cant see leak with flashlight anywhere yet it is wet above and onto driver side intercooler face either tank cracked, failed seal or tank gasket or pinhole in core itself,
new o rings for oil cooler fitting, upper lower hoses r less than a year old
ready to finish this project,
      03-19-2022, 06:08 PM   #14
m1256
31
I'm on my third radiator by 71,XXX miles. All OEM BMW radiators. The one that was just replaced separated, plastic from the aluminum part.
      03-25-2022, 10:28 PM   #15
PR X13.5i
Puerto Rico
12
Drives: BMW X1 xDrive 3.5i
I've owned my 2013 35i since April 2021. Just killed the fifth radiator in a year. They've all died the same way. Separation between the plastic and the aluminum. Love this car but is really annoying to have this happen every couple of months.
      03-25-2022, 10:49 PM   #16
0w40X1
34
I suggest that under boost the head gasket can let the coolant be pressured causing radiators and bottles to crack, especially with 5 in a year.
      04-04-2022, 06:07 PM   #17
jdh212
Drives: BMW X1 E84
Another cracked radiator
14 X1 sDrive28i at 90k miles. Previous owner replaced radiator at 66k miles.
My car just went in for service, I had the low coolant light come on. Had to top it off 1-2 before I was able to get it in for the service. Same issue as you guys, upon inspection it looks like the plastic has separated slighting from the aluminum causing a leak. Getting a new radiator and some fresh hoses tomorrow.
Hard to believe so many of us all have radiators failing 1-2 times on sub 100k mile cars. Thinking it may be time to part with this car soon. Doesn't sound like the mechanics are big fans of this N20 motor.
      04-05-2022, 05:55 AM   #18
Kriston
The Ultimate Driving Machine
Kriston's Avatar
151
Drives: Like Donkey Kong on Roids
Replaced my radiator at 100K KM. Notorious problem on the e84. If it goes again I'm getting an aluminum rad and calling it a day.
CHUCK NORRIS ON WHEELS
      04-10-2022, 02:11 AM   #19
Mark-It-Zero
Mark-It-Zero's Avatar
Drives: 2013 BMW X1 xDrive35i
Keeping careful watch on mine since it's getting close to that point and just replaced the expansion tank 2 weeks ago, but struggling to find an aluminum rad.
Seems like the CSF 7046 would manage to fit, but response I got from CSF is they don't offer anything for E84 35i auto
2013 X1 xDrive35i M Sport package
2005 Lotus Elise
      04-11-2022, 06:59 PM   #20
bosstones
1154
Drives: o_0
Are you guys all tuned? Or is this an issue even with a fully stock setup?
      04-11-2022, 07:27 PM   #21
jdh212
Drives: BMW X1 E84
BONE STOCK
Mine is bone stock. I definitely am a more spirited driver but I'm not tracking or beating the crap out of my car. Doesn't make sense.
bosstones1154.00
      04-11-2022, 07:29 PM   #22
m1256
31
Stock, I drive it like a grandpa.
bosstones1154.00
Tags
collant, crack, leak, radiator
