04-24-2018, 12:16 AM | #1 |
239
Rep 170
MCS Install Questions
- Are there any bump stops used? I dont see any, I could reuse some stock bits.
- Are any of the stock parts retained for the rear dampers? I have the power flex race tops, but should the factory washer with bump stop be the first part of the stack? My guess is no. - Anyone have a caster and ride height recommendations? Thanks!
2012 E92 M3 ZCP MCS 2WR coilovers 600F/900R, Performance Friction ZF54 front BBK, stainless lines, Ferodo DS 2500 rear pads, Hotchkins F/R swaybars, solid subframe mounts, BE Bearings, ARP rod bolts, Bimmerworld motor mounts, AFe intake, underdrive, CSF radiator, GT4 front lip (ebay), APR GT 500, ebay side skirts, RaceEng tug, 15mm/10mm spacers on ZCP wheels, Apex ARC 8 18x10 square track wheels with Pirelli 265 DH slicks
04-24-2018, 01:11 PM | #2 |
///M Powered for Life
11490
Rep 10,329
I've done this install a few times. Good choice BTW with the PFC BBK and the MCS!
Caster: I was told 'as back as possible' so it's what I did on both camber plates. Ride height: You basically want to go as low in the rear as possible until you hit the fuel filler neck on the passenger side. Eventually you'll be so low in the front that you'll rub the top of the wheel wells. That's too low Bump stops: None that I'm aware of front or rear. Not sure this is correct though |
04-25-2018, 11:23 PM | #3 |
239
Rep 170
BW confirmed no bumps stops. Guess you don't want another thing acting as a spring - but never had a car without them.
I've got the Ground Control race plates and it seems like to get any real negative camber you cannot run maximum caster. You are fighting the circular hole in the chassis, and as the strut moves back you can't get it in as far for the camber. So is this just a balance you make?
04-25-2018, 11:32 PM | #4 | |
11490
Rep 10,329
I have the same plates as you and that's how I did it. |
04-25-2018, 11:41 PM | #5 |
239
Rep 170
Must not get out plasma cutter........
