03-08-2018, 10:41 PM | #1 |
Rep 27
Race prep questions
Yes I read the FAQ's..
I recently got a higher mileage 2011 e92 m3 138k and I'm just gonna track it. IM not familiar with the s65 since I've only had e36's, and 46's so what do I need to do to keep this old girl happy on the track. What issues need to be addressed? the rod bearings have never been replaced and the throttle actuators. upgrade the radiator or fans? larger or large oil cooler? besides the brakes and fluids thanks guys really appreciate the guidance |
03-08-2018, 11:08 PM | #2 |
850
Rep 1,679
Really depends on how hard you'll be pushing it. At that mileage I'd for sure do the RBs. Beyond that, start simple with brake lines, SRF, pads and decent tires.
03-09-2018, 06:54 AM | #3 | |
///M Powered for Life
11490
Rep 10,329
I'd leave the TA's alone until they start giving errors. The cooling system is fine. You probably want to do a coolant flush |
03-09-2018, 07:20 AM | #4 |
Enginerd
118
Rep 542
Compared to the chassis issues of the '36 and '46, the E9x chassis hasn't shown any major weak points, save for differential bolts snapping. Since you're tracking and NVH is not of a concern, look into doing solid rear subframe mounts and upgraded (poly) diff mounts. That should help shore up the rear end and limit the flex on the diff bolts that can fail in shear.
Stock brakes are fairly competent with just upgrading lines, pads, fluid for HPDE. During longer use you might start to see fade and need additional cooling and possibly bigger brakes. Goodluck and enjoy that soundtrack, at full song the S65 is glorious
2008 E92 AW 6MT /// 120k orig rod bearings
03-09-2018, 12:28 PM | #5 |
Rep 27
wow awesome guys really appreciate the help and time.. thanks again.
do you feel i should do the rod bearings anyways or leave them alone if they haven't failed yet.. I push the car pretty hard and it lives mid to top of rpm. |
03-09-2018, 12:49 PM | #6 |
75
Rep 387
What do your oil tests indicate?
03-09-2018, 12:53 PM | #7 | |
850
Rep 1,679
The issue is not whether the RBs will fail, but rather when they will fail. |
SYT_Shadow11490.00 |
03-09-2018, 01:05 PM | #8 |
Enginerd
118
Rep 542
Do the rod bearings. You have no prior data/knowledge about how the car was driven or cared for and it's going to see proper abuse. When they go... so does your engine.
Shop cost is $2500-3000, DIY for $500-1000.
03-11-2018, 11:35 AM | #9 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I would replace the radiator and oil cooler. If you're keeping the AC, blow out the condenser really, really well. If it's a DCT, consider replacing the cooler for that or at least blowing it out.
Before you get aftermarket stuff, I haven't seen a huge difference as posted here. I think it's mostly because the coolers are thicker. So you're cooling with warmer air at the back of the radiator. I had a Zionsville in my E46 and it maintained the same peak temps, get a little more run time before you overload the system but it does cool quicker during the cool down. Kind of useless IMO unless you need to cool the car down quickly. Then replace the drive belt. A broken belt on track will be disastrous.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
03-12-2018, 08:52 AM | #11 |
239
Rep 479
Yep, I replaced my bearings as preventive maintenance. I've been attending track events once a month for 2 years, and have gotten healthy oil reports. I change my oil every 3 events. Never had to worry about my engine blowing. Paid 3k for parts and install, but its good insurance verses paying for a engine and labor.
03-12-2018, 09:01 AM | #12 | |
11490
Rep 10,329
Did rod bearings this weekend to a 60k M3 and the mounts were split apart in several parts. The mounts in my 30k E92 and 36k E90 were already starting to crack |
03-12-2018, 09:05 AM | #13 |
239
Rep 479
LOL yep, did Bimmerworld polyurethane engine mounts. The engine vibration wasn't even noticeable.
