03-01-2018, 09:14 PM | #1 |
326
Rep 535
fender flares, etc to allow for wider tires?
I don't see too many builds in which it fender extensions were included to allow for wider tires to be fitted in all 4 corners. Or I just haven't searched deep enough?
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
03-02-2018, 12:08 PM | #2 |
winner of many hpde trophies
47
Rep 120
How wide do you want to go? You can already fit 285s easily and that's about where the tire selections end. I think there's someone running 305 hoosiers, not sure what you have to gain by going over that other than increasingly expensive tires and adding weight.
ricardofors68325.50 |
03-02-2018, 01:19 PM | #3 |
503
Rep 1,055
You could go the GT2 route:
https://gthaus.com/aerodynamic-parts...-m3-body-kits/ |
03-02-2018, 01:37 PM | #4 |
49
Rep 243
You could also go with the liberty walk kit, it's expensive. But you'd be able to fit some wide wheels.
http://libertywalk.co.jp/bodykit/lb-works/bmw-m3-e92/ |
03-02-2018, 01:49 PM | #5 |
11586
Rep 12,728
There may be a diminishing benefit once you push the wheels out to go wider. You start to effect the scrub radius and leverage on suspension components if you don't actually widen the track width of the car. Something to think about.
I've often wondered about notching the frame up front to for larger tires, but I'm not serious about it yet, so I haven't taken a real look at it yet...
Instagram; @roastbeefmike
03-02-2018, 07:19 PM | #6 |
326
Rep 535
So there is an end to how much is too much tire width size-wise
03-03-2018, 07:25 PM | #8 |
326
Rep 535
My goal is to use as much tire width as possible
03-03-2018, 07:26 PM | #9 |
847
Rep 1,679
A gentle roll of the rear fenders is all you need to do. No fugly wide body pieces needed.
03-03-2018, 08:19 PM | #11 |
4985
Rep 11,891
All cars that park at Starbucks cars and coffee has liberty walk non-functional body kits and bags
SYT_Shadow11490.00 |
03-05-2018, 12:15 PM | #12 |
721
Rep 2,342
I fit 18X11 305 square under stock fenders.
The LB kits you need 12-13 inch wide rims and low offsets to fill up the wheel wells. You'll need some power to really benefit from the tire you'd put on a 12-13 inch wide rim. |
03-05-2018, 12:28 PM | #13 | |
2760
Rep 5,483
There's a big difference between "Say Unto Me What Fits, O Great And Powerful Internet" and "what will fit if I exercise at least more than one single solitary brain cell to conduct independent research and validation" and that's why there aren't many threads about flares
EDIT: Found my notes on here about that test-fit. Wheels are narrow because this was SCCA Stock class. 9.5 ET22.5 effective width/offset One of the advantages of using the stock spring perch location is the great tire clearance, and the MCS dampers are a little smaller OD than the stock dampers so there's more room now. The 315's fit on the front with 18x9.5ET35 and 12.5mm spacers, but they stick out about 1/4" from the fenders. This *might* tuck in as the car rolls but I'm not going to find out. They also rub slightly on the back of the fender liner, but they fit, and don't rub at all in the front of the fender. So a little relieving of the fender liner with a heat gun or whatever, and more camber would probably make them fit comfortably, *without cutting the fenders ! This could be big in a more modified class as you can go pretty wide with the tires without making the car wider. You could even do this with coilovers with the right spring and perch... So yeah. Agree flares are unnecessary. You can get a 295/30-18 Hoosier on the front of these cars very easily on a 10.5 with the offset selected appropriately, that tire fits comfortably in back too as does the 315 I was just talking about. You just can't go tall. Has to be a short tire up front Also, these cars can run 17's with brakes selected appropriately, and Hoosier makes a 295/35-17 and 315/35-17 for the 'Vette and pony car guys and old P-cars. widening beyond the existing geometry much more than what MasteP is talking about up front just torpedoes the scrub radius anyway, even with the fancy knuckle you start to get out there in "better stop the suspension from working or it will work really poorly" land
scotty_miller184.50 SYT_Shadow11490.00 |
03-05-2018, 03:51 PM | #14 | |
Stop the hate, get a V8
3850
Rep 8,625
This. I wouldn't look at body modification for wider tires until you've basically proven that you are running out of tire. That's been my approach to almost any sort of upgrade or replacement part.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 03-05-2018 at 04:00 PM.. |
kyippee1073.00 |
03-05-2018, 07:07 PM | #15 |
326
Rep 535
Point well made and taken. Plenty of grip to be had without modifying the fenders. Thank you.
