02-26-2018, 02:22 PM | #1 |
112
Rep 103
Vibration more than 90mph
Hi guys the center bore of my rims are smaller than the bore of the car. Do you guys think wheel ADAPTER will fix this?
My rims aren't made for F8X. They're work wheels sc2 and I believe they're for lexus lol. Yes I know might as well buy new rims. I just need an answer for cheaper solution lol. Thx guys. |
02-26-2018, 04:32 PM | #2 |
1326
Rep 1,481
I'm not sure how you got it to fit, your bore of the wheel is smaller than the bore of your car, or do you mean the opposite? Also isn't lexus 5x114.3? Are you running a spacer with a bolt pattern adapter? to convert the 5x114.3 to bmw 5x120?
If your wheels are 5x120 with a bore bigger than OEM bmw size, thats very common and just add a hub centric ring to address the shakes and wobbles. If its with bolt pattern conversion/adapters and spacers then you need to buy some correct fitting wheels.. |
revenlymokalu112.00 |
02-26-2018, 08:22 PM | #3 |
13
Rep 126
OP as stated Lexus has a 5x114.3 bolt pattern, also you would never be able to get the wheel on if the wheel center bore was smaller then the vehicle center bore, no way it would work. Please check your set up again and some one here will be able to help you
02-26-2018, 10:33 PM | #4 | |||
112
Rep 103
Hi guys. Thanks for replying. Actually it not smaller but it just sits perfectly in front of it so centric hub won't do anything. It's like facing each other. |
02-26-2018, 10:55 PM | #5 |
1326
Rep 1,481
Doesn't sound safe.. so your wheel isn't sitting flush on the hub and is held on by just your lugs? No way to fix your problem..
02-27-2018, 03:20 AM | #6 | ||
112
Rep 103
New rims is the answer I guess lol |
02-27-2018, 07:04 PM | #7 |
254
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
Not to mention your year tires look very stretched
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
