02-26-2018, 09:47 AM | #1 |
22
Rep 24
Drives: 2011 BMW 135i
Hyperblack VMR V703 "VB3"
Hey guys, I'm looking for a set of 18" VMR VB3's in hyperblack. Bavarian Auto is the only place I've seen that has them, but they say the offset won't work with the 1 series. If anyone knows where to find a set let me know!
03-06-2018, 03:17 PM | #2 |
Rep 16
You can definitely run them on 1ers. et45 all arround, lots of people run them. You won't be able to fit the most aggressive tire though. Check Mod Bargains... I actually just picked up a set from them in gunmetal!
03-13-2018, 02:47 PM | #3 | |
22
Rep 24
03-16-2018, 07:09 PM | #4 |
94
Rep 269
ET 22 is not enough offset for a 1-series with even mild tire options. If you want to get even a little aggressive with tire size, I think ET45 would be the minimum I'd use.
Just to show that I'm not blowing smoke, I wanted 17" wheels instead of the 18" BMW Performance 182s that I have. I ended up ordering these from BMW because they have 47mm of offset so that I can run 225/45-17s, at least in models that aren't wide at the tread AND section width. http://www.realoem.com/bmw/enUS/show...52#36116751364 |
