02-21-2018, 06:12 PM | #1 |
276
Rep 538
6mt question
I am getting ready to move on to 6mt from dct
I have test drove before but one question came up in my head So this auto rev match thing ... If I shift into lower gear, it automatically rev matches for you even tho you don’t let the clutch out .. So my question is if I was going 60 and put into 2nd and keep the clutch in, in regular car it will be fine until I let the clutch go .. But in auto rev match, will it blow up??? Or it won’t rev match since car knows it will over rev? Thank you advance ! |
02-21-2018, 06:18 PM | #2 | |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
02-21-2018, 06:30 PM | #3 |
276
Rep 538
02-21-2018, 06:34 PM | #4 |
10785
Rep 8,852
Autorev match will not exceed redline.
02-21-2018, 06:36 PM | #5 |
5002
Rep 6,864
No the rev match is still limited by the cars redline. It would not over rev unless you let out the clutch thereby forcing the revs above redline.
02-21-2018, 06:43 PM | #7 |
6582
Rep 5,304
As others have stated, the rev match will not blow up the motor.
If you money shift, it won't be the rev match that does it. It'll be because you put it in the wrong gear and engaged it. |
02-21-2018, 07:23 PM | #8 |
1538
Rep 1,665
I almost money shifted my car when I accidentally pulled the shift lever from 3rd near redline into 2nd instead of 4th. The auto rev match worked as intended shooting revs sky high. Don't know if it exceeded redline or reached fuel cut off because I immediately pulled it out of 2nd gear. Thanks to the super loud/high rev, I didn't release the clutch pedal and saved myself from a money shift.
So, yes, it WILL try to match revs, but only YOU can money shift by releasing the clutch. Even if the ECU was smart enough to know that it shouldn't try to rev match in a lower gear, and is programmed to ignore the mis-shift into the lower gear, the second you release the clutch pedal, because you have placed the transmission into a gear that will spin your motor past redline, YES, you will money shift even if rev match doesn't work. This is how people traditonally blew up their motors back when rev matching didn't exist. |
02-22-2018, 03:14 AM | #9 |
34
Rep 155
Just wanted to say enjoy brother, fun powerful rwd manual trans 4door, probably the only car on this planet in production with these features and maybe the last.
02-22-2018, 09:50 AM | #10 |
10785
Rep 8,852
OP has an M4
02-23-2018, 12:12 AM | #11 |
34
Rep 155
02-25-2018, 11:16 AM | #12 |
276
Rep 538
02-26-2018, 12:11 AM | #13 | |
34
Rep 155
Ill tell you what.. i used to look down at bmw and anyone who buys an over priced underpowerd car never thought in my wildest dreams there would come a day that id own one or a 6 cylinder .. it only took one test drive to change that. |
SakhirM410784.50 |
