XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      02-15-2018, 11:30 AM   #1
Ja Gio
23
Drives: X1 xDrive28i, 2013
Turbo replaced under CPO
From time to time over the last two years when starting my 2013 X1 x-drive 28i I would get the Engine Malfunctiion warning, and the thing would go into reduced power mode. Over and over, I just cleared the codes with the Carly app and I’d be on my way. Sometimes just restarting would do the trick. It was always the same 3 codes, once in a while a few more:
Engine / Motor
:Lambda probe before catalyst temperature
Code: 002CAA
Charge pressure control, shutdown: pressure build-locked
Code: 002C58
sorry, unknown fault
Code: 002CA4
Last Thursday, fortunately, I was heading in the direction of my dealer, late in the afternoon, and it occurred again. This time I drove straight to the dealer. Thank goodness it’s still under CPO - they replaced the turbo, along with the charge pipe - it only cost me the $50 deductible. Heads-up if you get these codes!
      02-15-2018, 11:48 AM   #2
darkrom
darkrom's Avatar
188
Drives: 135i
What did they say failed specifically?
      02-15-2018, 12:23 PM   #3
themishmosh
36
Drives: BMW X1 xDrive35i
Just reduced power mode? My 35i will do 4x4/dsc malfunction once in a blue moon. Not sure why?
X1 35i, H&R springs, Bilstein HD shocks, BMS JB4, BMS chargepipe, xHP trans flash
      02-15-2018, 02:34 PM   #4
Ja Gio
23
The only sign anything was amiss was “reduced power”. Sometimes just a restart cleared it (but left the codes), sometimes I needed to diagnose then clear codes with Carly. Clearly, I should have addressed it earlier, but fully intended to before hitting 100k.
      02-15-2018, 02:38 PM   #5
Ja Gio
23
They did not button it down to specifics, it’s more that the technician followed required steps in diagnosing, then the program prompted him to take certain actions. I don’t have the papers here, but it all started with a data point being out of range. I’ll try to remember to post a photo of “the story” later.
      02-15-2018, 02:43 PM   #6
mcdanielvzw
mcdanielvzw's Avatar
144
Drives: 2021 X3 M40i (times 2)
How many miles did you have on it?
I'm hoping that the reduced backpressure (catless DP) will offset the increased boost from my JB4 so my turbo lasts a loooooooong time on my 35i. Lots of oil changes, for sure.
      02-15-2018, 03:22 PM   #7
Ja Gio
23
i
A little over 92k, running a DINAN chip fit about 50k.
