XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      02-11-2018, 06:20 PM   #1
Busta Rib
Busta Rib's Avatar
16
Drives: F25 X3
How to get wheels flush with the fenders
I've searched over 5 pages of threads trying to find my answer and couldn't so I am posting a new thread. Apologies if this has been covered before. I am trying to figure out what is required in order to get wheels on a lowered X1 to look flush with the fender. There is a wide lip on the fenders of our cars and I am wondering how people get their wheels to fit without rubbing.
Do you have to dremel the lip? Is it do-able and is there a DIY on the best way to do this? I am planning on buying a set of 19" summer wheels/tires for my car and just want to figure out what needs to be done in order to get the best fitment and look. Thanks in advance.
It's difficult to tell how it's lowered but here is a pic of my car for reference
2014 X3 M Sport Space Grey/Black
      02-11-2018, 08:47 PM   #2
boosthead
40
Drives: 2009 328ix
Often, folks accomplish this using wheel spacers or wider wheels and tires. I originally used spacers and OEM wheels on my e90 before swapping them out for much wider Apex wheels with no spacers.
      02-11-2018, 09:36 PM   #3
Busta Rib
Busta Rib's Avatar
16
Drives: F25 X3
I get that. The issue is with the lip on the fenders. It is about 1.5" wide. If you push the wheels out to be flush with the edge of the fender, it seems it would rub on the lip. I am wondering if people who are running spacers are having issues with rubbing on lowered cars or if they are cutting the lip with a dremel or something else.
      02-13-2018, 05:48 PM   #4
VacMan1
Drives: 2017 i3, 2015 Msport X1
Google "Fender rolling."
      02-13-2018, 06:07 PM   #5
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
They won't. Unless you're lowering the car a ton. On H&Rs, for example, you can run them flush and they won't rub. The top of the wheel gets tucked into the fender a bit under compression. Plus, as you lower, you'll add negative camber, tucking the top of the tire even further.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      02-14-2018, 12:17 PM   #6
zeevette
Unllicensed
zeevette's Avatar
29
Drives: 2013 X1 35i
Based on your picture, your car looks great now. I was going to lower mine, but it's already about a foot shorter than an X3. My wife hates driving my car because it's too low. (stock)
      02-14-2018, 01:42 PM   #7
Busta Rib
Busta Rib's Avatar
16
Drives: F25 X3
Can't roll plastic
      02-14-2018, 01:59 PM   #8
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6430
Drives: 2022 X3 M40i BG/Taco Red
The OP's X1 is definitely lowered.
We think H&R - Busta, you ever get a chance to check?
      02-14-2018, 04:57 PM   #9
Busta Rib
Busta Rib's Avatar
16
Drives: F25 X3
Haven't checked yet. I might be buying a new set of wheels this weekend. If I do, I will put them on and take the opportunity to check the springs. It is definitely lowered, just don't know how exactly.
      02-15-2018, 12:01 AM   #10
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
Go on the Facebook page for e84. You will get a quicker response. This a picture of my rear that is trimmed. 18x12 et15 295/35/18, I am also on KWv1s so I can adjust it if need be. [IMG][/IMG]
      02-15-2018, 12:11 AM   #11
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
The arrow is the middle metal tap that will need to be removed or bend upwards. I highlighted the areas that will rub. I removed all the plastic up to the metal lip. About a 1/4"-3/8" plastic before you get to the metal lip. Hopefully the picture helps you
      02-15-2018, 10:54 AM   #12
Busta Rib
Busta Rib's Avatar
16
Drives: F25 X3
Thank you! That helps a lot.
      02-16-2018, 07:26 AM   #13
hooligan_G01
6430
