02-04-2018, 09:35 PM | #1 |
42
Rep 144
Ugly Fender Gap - Springs??
http://www.m3post.com/forums/showthr...8#post22742248
Guys, looking for an economical solution to eliminate the fender gap on my all stock 08 E90 M3. Anyone have good condition springs you'd be willing to sell at a good price? Thanks in advance. Learning a lot from this forum. Pic here (updated w/my car): https://www.dropbox.com/s/51g71qy4x1nlml2/car.jpg?dl=0 Last edited by turbosocal; 02-06-2018 at 10:56 PM.. |
02-05-2018, 05:53 PM | #3 |
42
Rep 144
02-06-2018, 02:34 PM | #4 |
Rep 38
From my experience, swift springs provided the best compromise between performance and ride quality. Definitely not the lowest drop, but sits flush with OEM 19's- the gap gets reduced to about enough room to fit one finger.
Just so happens there is a forum member on the CA forums selling the springs and local to socal (I am not affiliated with him): http://www.m3post.com/forums/showthread.php?t=1450661 Hope this helps! |
02-06-2018, 07:57 PM | #5 |
208
Rep 651
Drives: 2008 Melbourne Red M3 Coupe
I've got some Eibach Pro Kit springs in the garage that I can let go for whatever half price of new ones are these days. They worked well and provided a nice stance and good ride (I went a different direction and now run KW club sports). Let me know if you are interested. I'm in Riverside.
Here is a pic with the Eibach springs: |
02-06-2018, 08:54 PM | #6 | |
42
Rep 144
Man, thanks! Checking that out now. Is there anything else I would need when swapping out the old springs? I see a lot of talk about bump stops and bushings, but I don't know much about these. Also, how much $ should my local shop be charging to install these? |
02-06-2018, 09:46 PM | #7 |
892
Rep 9,032
How old are your shocks?
BMW shocks/struts tend to suck after 40,000 miles. Might as well change them out and be good for many years for most people. Dinan shaves down the front strut tower tops to give more travel. They may use slightly shorter bump stops too for the same reason. There's a nice thread for many years ago on this topic. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
02-06-2018, 10:54 PM | #8 | |
42
Rep 144
My shocks are stock, 90k miles. |
02-07-2018, 09:22 PM | #10 |
208
Rep 651
Stocks shocks with lowering springs ride fine from my experience, however 90k miles may have used then up and simply adding lowering springs will not solve the problem. Since you might need new shocks and springs I would recommend looking at an adjustable coil over set up like the Ohlin, KW, or Bilstein.
02-08-2018, 02:05 AM | #11 |
Rep 38
At 90k miles I definitely recommend ponying up some extra cash and get a coilover setup since you would be due to replace your oem shocks. It will save you a lot of time and money in the very near future. On another note, aftermarket springs with stock shocks work well but they add extraneous stress on your shocks vs oem springs. If your shocks are already at 90k, they will likely wear out even faster with aftermarket springs.
Like others have said, look into brands like KW, Ohlins R&T, or Bilstein. They offer great quality coilovers for both street and track usage. Shameless plug- I am taking off my KW V3's from my E92 M3 this month and having them completely rebuilt by KW. I was quoted $800 with a 3-4 week turnover. But if you are interested in purchasing them from me and sending them in yourself, I could let them go for $600. Meaning, you could have newly rebuilt KW V3 coils for just $1400. PM me interested! |
02-09-2018, 07:31 PM | #13 | |
42
Rep 144
02-09-2018, 07:34 PM | #15 |
42
Rep 144
02-12-2018, 02:22 PM | #17 |
1341
Rep 1,881
I bought my e90m3 bone stock, installed lowering springs, car rides like crap over bumps and potholes. and yes I used the shorter bump stops, doesn't help. car bounces all over the place, but felt fine with the stock springs. granted I live in a city with horrendous roads, but not as bad as Manhattan.
Yes the car looks good, but at the cost of comfort and handling? no thanks. Ohlins R&T is my next upgrade. |
02-12-2018, 09:17 PM | #18 | |
42
Rep 144
02-12-2018, 10:13 PM | #19 |
66
Rep 228
On the other hand, I'm on Bilstein B6 with Swift Spec-R springs and the car handles beautifully with a ride that is as comfortable as stock, only different.
