01-26-2018, 02:19 PM | #1 |
Assistant to the Regional Manager
27
Rep 149
Adjustable and Chassis-mounted front splitter options?
After hours of searching I can only find the OEM GTS one thru IND for like $4K+
Other than buying the components separately (lip + splitter) and finding a shop to fab the chassis mounts and make it length adjustable (guessing not easy), are there any other options you guys have found? I want to run the GT4 mkII wing (à la Lukester), which is also adjustable so I like the idea of 1) having one or two front settings to balance rear on track, and 2) provide some rub protection while street driving (retracting splitter to line up with lip) Car is dual duty, I'm basically going for an M3 'GT3' build Any guidance is appreciated!
'08 E92 M3 DCT, AW on Fox Red
01-26-2018, 03:33 PM | #2 |
///M Powered for Life
11490
Rep 10,329
People should come up with plenty of options for you. There are many besides the OEM GTS splitter
01-26-2018, 04:03 PM | #3 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
@HARDmotorsport might have a solution for you.
I run the kit now but my oil cooler is relocated.
01-26-2018, 04:51 PM | #4 |
27
Rep 149
Awesome recommendation and they are in my backyard. How did I not know about them!? Will reach out to them.
01-26-2018, 04:53 PM | #5 |
27
Rep 149
For those who are running a chassis mount splitter, can you comment on which brand/model you went with and who fabbed the pieces?
01-26-2018, 05:02 PM | #6 |
11586
Rep 12,728
i bought the hard motorsport mount a while back, but was told it wouldn't fit right because of the routing of the oil cooler lines. i sent it back without even mocking it up.
Instagram; @roastbeefmike
01-27-2018, 09:13 PM | #7 | |
3221
Rep 6,218
xchosun1x has a gt4 wing and chassis mounted splitter. He could possibly help in here?
01-27-2018, 09:14 PM | #8 |
3221
Rep 6,218
As far as the adjustable piece. This is what I found.
One base aluminum bracket on fixed splitter with bottom piece that can be said back and forth (grooves instead of holes for screw).
01-28-2018, 03:58 AM | #9 |
11586
Rep 12,728
i've handled an oem gts lip in person and observed it on the car. pretty sturdy. i'm surprised it hasn't been replicated yet.
01-29-2018, 05:56 PM | #10 | |
27
Rep 149
Yea, same one I found although that pic looks slightly different but I believe it's the OEM GTS...
01-29-2018, 06:01 PM | #11 | |
27
Rep 149
My challenge would be asking the shop to create something from scratch and I'm fairly certain they'd need to remove the bumper and look at the attachment points before they could even give me an estimate
01-30-2018, 03:46 PM | #12 | ||
3221
Rep 6,218
01-30-2018, 08:07 PM | #13 |
11586
Rep 12,728
i'm leery about making a multi-piece metal splitter support... i don't want it coming off and creating a hazard to other drivers.
06-04-2018, 02:40 PM | #14 |
B.E.
444
Rep 761
Just spoke to hard, they said it has been redesigned to work with stock lines. Order placed and I'll update you guys when it arrives
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
roastbeef11586.00 |
06-04-2018, 03:08 PM | #15 | |
11586
Rep 12,728
06-11-2018, 02:30 AM | #16 | ||
B.E.
444
Rep 761
roastbeef11586.00 |
06-11-2018, 03:13 AM | #17 | |
11586
Rep 12,728
i have a gt4 style lip now, but i still might sandwich it with something for more rigidity. it is getting pulled down a little bit. thanks for posting pics of the hard mounts.
06-11-2018, 03:25 AM | #18 | ||
B.E.
444
Rep 761
I was thinking about using the hangers as another mounting point for the splitter but kind of destroyed the driver's side one accidentally. I haven't tightened up the bolts yet so can't comment on how rigid the mounts are, but I'll be reinforcing the splitter some more (will include pics)
roastbeef11586.00 |
06-11-2018, 03:41 AM | #19 |
11586
Rep 12,728
yea, i figured you would be getting rid of the felt with that splitter design. are you just tracing it out for APR to build a custom one?
since you aren't doing the side felt pieces, are you going to attach the fender liners to the splitter with some L brackets or something? ecs has those cables for about $40 each. https://www.ecstuning.com/b-genuine-...h/51758044393/ i'm interested in your project... keep us posted!
06-11-2018, 03:51 AM | #20 | |
B.E.
444
Rep 761
Haven't decided on the liner connection yet but I bought some L brackets just in case. We'll see tomorrow
06-11-2018, 04:06 AM | #21 |
11586
Rep 12,728
the only reluctance i would have with the wood is the weight... but its probably not as terrible as i'm imagining.
are you going to do some support rods as well? i'm thinking about tracing out something that goes from the wire hangers that extends diagonally to the front support rods. i'd probably extend the rods and drill into the carbon accident bar that is right above where i originally attached the rods to the bumper for more rigidity. the gt4 lip is "just ok" on its own. ideally, it needs some help keeping it from flexing.
06-11-2018, 01:02 PM | #22 |
239
Rep 170
You might consider real plywood as opposed to OSB. The strength is not the same with OSB due to the short fiber length, it also weights more with higher resin percentage. Alumalite as you mention is probably the best bang for the buck on strength vs weight vs cost.
2012 E92 M3 ZCP MCS 2WR coilovers 600F/900R, Performance Friction ZF54 front BBK, stainless lines, Ferodo DS 2500 rear pads, Hotchkins F/R swaybars, solid subframe mounts, BE Bearings, ARP rod bolts, Bimmerworld motor mounts, AFe intake, underdrive, CSF radiator, GT4 front lip (ebay), APR GT 500, ebay side skirts, RaceEng tug, 15mm/10mm spacers on ZCP wheels, Apex ARC 8 18x10 square track wheels with Pirelli 265 DH slicks
