BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      01-26-2018, 11:07 AM   #1
MShift
OG
MShift's Avatar
217
Drives: MW '13 E92
KW Clubsports - Need some help please
Hi Guys,
Would anyone be kind enough to post pictures of the the camber plates as installed without the factory plastic covers in the engine bay? Also, I have Comp wheels and they are rubbing on the spring. Anyone else experienced this issue?
      01-26-2018, 11:21 AM   #2
msan
403
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Think people use smaller eibach springs on the fronts to avoid rub
      01-26-2018, 12:22 PM   #3
elim11
424
Drives: e90m3
use a 5mm spacer in the front to avoid rubbing.
      01-27-2018, 09:16 PM   #4
M3 Number 86
3221
Drives: black m3
I just removed helper spring. Still use a 5mm spacer.
      01-28-2018, 08:40 AM   #5
JustAnothaM4
JustAnothaM4's Avatar
884
Drives: 2016 M4 GTS
2016 BMW M4 GTS  [0.00]
I removed the helper spring and running a slightly longer Eibach spring.
Replacement Springs: http://www.jegs.com/i/Eibach/369/140-60-0110/10002/-1
Info Thread on this subject: http://www.m3post.com/forums/showthread.php?t=973188
2016 M4 GTS Alpine White
2021 X5M Competition Marina Bay Blue
Instagram: @JustAnothaM4
      01-30-2018, 11:23 AM   #6
MShift
OG
MShift's Avatar
217
Drives: MW '13 E92
Thank you guys for all the info, added 5mm spacer and no more rubbing. Im surprised that I had to do that.
      01-31-2018, 06:58 AM   #7
Exclusivs
Exclusivs's Avatar
542
Drives: E92 M3
Your post is vague : sounds as if you are running wider tires up front , or lower then KW recommended height setting(s).
      01-31-2018, 07:45 AM   #8
Properstyle
506
Drives: 2011 e90 ZCP m3
not really the kw club sport springs go pass the top of the tire and rim. running almost any 9inch wheel with out a spacaer they will rub the spring. My ACS type 2 s that cleared fortunauto coilovers, rubbed the KWs same with my forgestars.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD
1994 300zx 2jz Swapped slicktop- The toy/track car
m3post
