01-07-2018, 07:34 PM | #1 |
Rep 10
2009 BMW E90 M3 Sedan 6MT, Space Gray
VIN:WBSPM93579E201353 Vin decoder: https://www.bmwvin.com/ Clean title/carfax Price: SOLD In short: 2009 LCI E90 M3 Sedan, 6MT, stock, rod bearing replaced, fully loaded. ~68000 miles The car is mostly stock except for the following modification: Ground Control camber plates for stock springs Eibach front adjustable sway bar Front aluminum under-tray (to replace stock fragile felt front under-tray) (http://www.m3post.com/forums/showthread.php?t=1364151) Minor tweaks: Wheel stud conversion Illuminated weighted shift knob from F10 M5 Rubber floor mats front, rear and trunk (stock ones included) Clutch pedal stopper Dash Cam hardwired (A119S) Bluetooth audio music adapter (Bovee WMA3000B) Recent Maintenance: BE rod bearing and ARP bolts, with new gaskets (@~64k miles @ SSR Performance) (original ones available, not excessively worn) OEM Engine mounts (@~64k miles) Spark plugs (@~65k miles) Brake: front and rear rotor (oem), front and rear pads (PFC Z-rated), ss brake lines, fluids (Motul 660) (@~64k miles) Intake air filter (@~64k miles) Cabin air filters (@~64k miles) Power steering fluid (turkey baster method) (@~64k miles) Transmission fluid (@~64k miles) Rear differential fluid (@~64k miles) Engine oil and filter (@~67k miles) Replaced Power/EDC/Traction button panel (Dec 2017) Last edited by KuriousJorge; 01-07-2018 at 09:23 PM.. |
01-10-2018, 10:32 PM | #4 |
4985
Rep 11,891
Since RB service is around $2k, this car is essentially a $28k listing. This is a fantastic price for what you're getting, MT, LCI, CIC.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-11-2018, 12:14 AM | #5 |
465
Rep 837
