12-30-2017, 06:56 AM | #1 |
194
Rep 305
stock LSD vs aftermarket LSD (on logger)
I installed aftermarket LSD (OS giken) and tested it on the track.
After test driving, I checked the logger data about rear (RL & RR) wheel speed difference. (red line is accel) I'm going to show you just objective data, not subjective. less understeer, much predictable oversteer, much consistent handling and much stable car movement => these are my first feeling But, my feeling may not be correct yet. I also changed stock front control arm to pillow ball control arm, and tested new LSD & control arm during only 1day trackday. So, Please refer to the objective data only.
2011 LCI W/DCT / K&N drop in filter / CSF radiator / do88 oil cooler / do88 DCT cooler / Akra Evo / Moton CS 2 way coilover / Wiechers strut bar(F) / ARC strut bar(R) / Alcon Superkit BBK / Tarox rotor / Geoff steel EHPS / Sard carbon-Kevlar GT wing / GT4 carnard / Aim Evo4+G-dash+GT Steering+S/C GP HD / Bride Zeta3 / etc.
12-30-2017, 09:46 AM | #3 |
5355
Rep 2,806
Drives: '09 E90 M3 - IB
It’s clear from the charts that the OS Giken is locking quickly on acceleration—much quicker than the stock diff. Once it’s locked, it stays locked more consistently than the stock diff. It’s also clear that the OSG diff is open on the entry into the corner, which is good.
With the characteristics shown in these charts, you should find the car more predictable on acceleration. You don’t show much braking activity. The last chart is perhaps the only chart where braking is going on. It’s not clear from that chart if you’re getting any locking on braking. Is this a 1-way diff? Or did you go 1.5-way (to get some locking on braking)? Did you have the diff custom setup for your specific car? (Spec-X setup) I have an OS Giken diff as well. I did a long 3-part write up on it that you might find interesting. It starts at post #173, then continues with charts at post #176 and concludes on #177: http://www.m3post.com/forums/showthr...1158445&page=8 |
CSBM52722.50 |
12-30-2017, 09:57 AM | #4 |
General
63381
Rep 24,678
Thought it was about dope .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M3 Number 863221.00 |
12-31-2017, 09:55 AM | #5 | |
194
Rep 305
The data is from the test and break-in track driving. I had to do soft driving because I changed final drive, too. haha Thanks for the information and I'll read your thread asap.^^b
12-31-2017, 09:58 AM | #6 |
124
Rep 137
The Giken (1.5 way) in it's stock setting transformed both my Cayman and Miata on track. I fully expect it does the same for the M3.
It's a shame it's such an expensive and PITA modification, or I suspect more people would do it. I've been dragging my feet on it....but thanks for reminding me.
'18 GT3 - 6MT
'13 E92 M3 - street/track '07 Cayman S - track car '15 FRS - Sprint racecar '00 Miata - Enduro racecar |
12-31-2017, 09:32 PM | #7 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
A clutch type diff is a potentially significant upgrade if you commit to throttle. A quicker locking diff will punish you for lifting. Also won't really help those who late apex every turn.
This is the first session with a 3 clutch diff in my E46 330...I think this was my 4th turn under a green flag? I lifted and it was all over from there...
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-01-2018, 11:18 AM | #8 | |
679
Rep 1,934
maicol76193.50 |
01-01-2018, 11:31 PM | #9 | |
194
Rep 305
01-01-2018, 11:47 PM | #10 | |
194
Rep 305
I think it is necessary to modify the program concerned with shifting (like accurate matching between rpm and speed, or rpm and gear level). If not, shock is about to make a mess, IMO.
01-02-2018, 12:39 PM | #11 | ||
1571
Rep 8,076
01-02-2018, 04:03 PM | #12 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
So where you able to change ratio in the computer for DCT?
I am switching to a new diff this season and should like to get a better final drive ratio but am hesitant since if you can't change the computer you risk a mechanics over rev.
01-02-2018, 06:26 PM | #13 |
194
Rep 305
01-02-2018, 07:00 PM | #14 | |
194
Rep 305
So, my friend contacted his friend, a professional and famous ecu tuner to find the answer, and I was informed by him that it is possible. Now I'm just waiting for him, because he is on vacation until mid-January. If modifying the program is success, I'll let you know the detail.
01-02-2018, 07:21 PM | #15 | ||
776
Rep 1,718
01-03-2018, 10:04 AM | #16 |
1478
Rep 2,672
I have the 3.45 diff and the full GTS DCT Tune, no issues at all. The oem DCT tune was fine as well. With the Alpine GTS DCT tune the rev-matching sounded a bit off, no functional issues though. I'm happy with the full oem GTS DCT tune now though so sticking with that, no need for special programming, IMO YMMV.
And thanks to OP for sharing, I am planning to get a new diff this summer and may try to install it myself, good info here.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
SYT_Shadow11490.00 |
01-03-2018, 11:17 AM | #18 | |
1478
Rep 2,672
LINK The rev-matching issue could have had something to do with my engine tune as well, I run Dinan Stage II and have the latest version of that tune now, when I had the Alpine DCT Tune I had an older version of the Dinan engine tune.
01-03-2018, 11:56 AM | #19 |
1478
Rep 2,672
As another data point I just looked over several rpm graphs and peak engine speed examples from my fastest laps at COTA and found 8300-8391 rpm or so to be the max recorded. The Dinan tune should set an 8600rpm redline (which I may have hit a few times, need to find those examples). I guess the fear is a downshift overrev though, I don't believe I've encountered any of those either.
From my fastest COTA lap, peak rpm on the front straight, S65 bouncing glorious noise off the grand stands:
buddalun679.00 |
01-04-2018, 12:04 AM | #20 |
1571
Rep 8,076
Anyone run a 3.62 without issues?
01-22-2018, 01:43 PM | #21 |
2362
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
I have Superlock on my E36. Rides like a train.
Pass me if you can.
