XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      12-26-2017, 09:55 AM   #1
thecos
Drives: 325i E46
17" OEM Wheels on the E84
Hi guys, I'm looking to downsize the wheels on my 14 35i with M Package from the 19" 225m to a 17" wheel. I know the front brakes can cause clearance issues with some wheels so I'd like input from other 35i owners that've mounted 17" wheels.
Please post your 17" wheels with specs, OEM or otherwise. Pictures are always worth 1000 words. Thanks!
      12-27-2017, 09:32 AM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
35i came with 18" or 19" rims because the brakes are fairly large. Most stock wheels have a ET30 + or -. The brakes sit pretty deep inside the barrel of the wheel. Even the rear brake is larger than the front brake on the 4. Are you looking for more sidewall or lowering it more? Look on the X1 picture /video/ media section , go to the " Official tire " thread and see MR JACK's 35 on 17s.
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      12-27-2017, 10:48 AM   #3
thecos
Drives: 325i E46
I want more sidewall. I did see his car on 17" APEX wheels but I'm considering OEM BMW wheels before I buy a new aftermarket set. I spec'd out a set of TireRack's C4 wheels which should fit according to their site.
      12-29-2017, 08:55 PM   #4
PrematureApex
840
Drives: N55 X1, N54 135, s54 m3
Best bet is to search the E90 forums. I'm sure there are a lot of 17" wheel threads, especially when it comes to snow setups.
Same brakes on a 335.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      12-31-2017, 10:01 AM   #5
BeEmVe
259
Drives: '14 X1 x28i M-Sport
A good source is http://www.bmwstylewheels.com you can check the 17" made for the X1 http://www.bmwstylewheels.com/X/X1-E84 (ET34) and then check other wheels.
FWIW we have done 18" wheels for summer and winter.
      01-01-2018, 05:04 PM   #6
thecos
Drives: 325i E46
Thanks guys. I figured it would be the same as the 335i but wasn't sure.
BeEmVe, I was more concerned with the brake caliper clearance.
      03-01-2018, 11:35 PM   #7
zoul
Drives: 2015 X1 35i
I'm curious, did you ever find out if this would work?
      03-02-2018, 01:40 AM   #8
mangoango
Drives: Wife & kids crazy
This member is running 17s in this pic. You can read about it here:
http://e84.xbimmers.com/forums/showt...6#post18574366
      03-02-2018, 05:29 AM   #9
bmwx1sq
bmwx1sq's Avatar
145
Drives: BMW X1 35i
I think apex is the only rim that will fit with the brake calipers.
      03-02-2018, 11:58 AM   #10
zoul
Drives: 2015 X1 35i
Thanks! I was thinking about putting a set of Style 393 Wheels on it, but now I really don't think that they will fit.
      03-14-2018, 06:55 PM   #11
fiehlsport
50
Drives: '13 X1 xDrive35i
My 17" Winter setup on my 35i. The brakes are *so* close. :-)
Sport Edition P4 17x7.5" 32mm offset with 225/50/17 Tires. Same diameter as stock.
      03-17-2018, 07:16 PM   #12
Mtpisgah
14
Drives: 2010 WRX & 2013 X1
I love those five spokes.
      03-18-2018, 07:57 AM   #13
PrematureApex
840
No, there are a lot. They're 335 brakes. Many people running many, many 17s as their snow setups.
bmwx1sq145.00
