11-23-2017, 11:01 AM | #1 |
492
Rep 577
Bad vibration after track day
Hello all,
I recently took my car to the track for the first time - I have a '95 M3 Track car and have been driving on track for a while, but decided i wanted to test out the E92 for a change and see how it stacks up. I swapped my wheels for the track session and put my "Daily" wheels back on afterwards. Now, I notice a pretty bad vibration under moderate to hard braking and even sometimes i get shaking in the steering wheel occasionally, almost as if the wheels are not balanced properly. I would think tire balancing, but the car drove perfectly before the track and i didn't run these wheels at the track, so no reason to assume the wheels magically came unbalanced from taking them off and then putting them back on; also the shaking while driving is random - its not consistently at "X" speed or above. I am thinking it COULD be rotors warped, but, my brakes have less than 20K miles on them (Rotors and Pads) and i know what i am doing at the track so i dont sit on the brakes after an out session, i dont put the e-brake on, i take a full cool down lap, etc... I dont want to dump a ton of $$$$ into new brakes for that not to be the problem - especially considering my rotors and pads are very new. Any thoughts/ideas? Anyone ever have something similar? I suppose it could be suspension bushings wearing - it just weird that it was perfectly fine, no issues whatsoever before the track and now it feels like its going to vibrate apart after the track :-(
Instagram: @MinionM3
Current Garage: 2012 M3 ZCP, Mineral White, DCT: Track Build 2020 M2CS, Misano Blue, 6MT |
11-23-2017, 11:12 AM | #2 |
11586
Rep 12,726
you can be pretty gentle on the brakes after a session and still get pad deposits. i hate to say it, but i think your front brakes are jacked... hopefully its just pad deposits.
what tires did you swap on? my first day on oem brakes after getting a set of track wheels with nt01's i fried my oem brakes. of course, this was a lot earlier in my hpde career, so i was probably on the brakes too much, but the moral of the story is that sticky tires with oem brakes = F'ed brakes.
Instagram; @roastbeefmike
11-23-2017, 11:15 AM | #3 | |
492
Rep 577
The tires weren't anything special - just the OEM Michelin PSS's It was a streets of willow tho, so super tight and lots of heavy braking zones Anyway to correct brake deposits or just have to scrap the front rotors/pads and call t a day?
11-23-2017, 11:32 AM | #4 |
11586
Rep 12,726
i've only been there once, but i don't remember streets being a brake eater. pss's aren't super grippy, either.
people often cite an abrasive brush device that they put into a drill and use it on the face of the rotor.... i have never done it and wouldn't. i'd be worried that i wouldn't do an "even" enough job and screw it up even more.
11-23-2017, 12:46 PM | #5 |
75
Rep 387
The usual first easy answer is "pad imprints". Have you pulled wheels and had a good look at the rotor faces?
Which pads? I'd drive it for a week or more before I started changing things. Maybe go through a bedding procedure and see if that helps. |
11-23-2017, 12:48 PM | #6 | |
492
Rep 577
This was about a month ago - have driven the car daily since and taken it on one hard run to see if hard braking again would cause everything to smooth out - it got slightly better, but still there. OEM rotors and OEM pads
11-23-2017, 12:52 PM | #8 |
492
Rep 577
Any suggestions on pads for this?
I daily the car and take it to the canyons every other weekend or so....
11-23-2017, 12:54 PM | #9 |
11817
Rep 23,187
For an intermediate pad could try ferodo ds2500s, or stop tech sr34. I've used both on street. They will squeal some on you though. Also used paid rs19 but they are tricky to bed.
11-24-2017, 04:39 AM | #10 |
85
Rep 330
It's definitely pad deposit. My steering wheel shakes like a vibrator every time I brake hard after a few laps on track with stock pads. For me, it usually goes away after a lot of street driving though.
11-29-2017, 02:57 PM | #12 |
748
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
Yep, pad deposits. OEM pads are bad for this.
Either get some track pads to clean the rotor, or try one of these: https://www.amazon.com/Performance-T...rds=rotor+hone
admranger2984.50 |
11-29-2017, 05:48 PM | #13 |
80
Rep 998
pad deposits, a couple weeks of daily driving should cure the problem.
2008 E92M3 6SPD stripper
2011 E90M3 DCT baby hauler 2010 997.2 GT3RS 3.8 weekend warrior |
12-13-2017, 01:33 PM | #15 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
Did you check the back of the rotor?
Warm the brakes up (NOT HOT)...spray with water and let the rotors rust up over night. Do one hard stop and your problem should be fixed. You have to spray the backside of the rotor as well.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
MinionM3492.00 |
