11-19-2017, 09:26 PM | #1 |
10
Rep 87
Squirrely from high speed braking question
I noticed my E92 getting squirrely from high speed braking before turn 10 at Road Atlanta. If I'm below 140mph, it brakes great. Over ~140mph, it got squirrely on me a couple of times. The instructor thought it was probably from my suspension. Any suggestions?
E92 fairly stock suspension with 3 degrees camber on Nitto tires. Stoptech ST40's with track pads. |
11-20-2017, 02:54 AM | #3 | |
2147
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
11-20-2017, 08:36 AM | #4 |
748
Rep 1,256
Drives: '08 M3, '09 328xi Sport Wagon
It's most likely your struts/springs combo. What kind of mileage are on them?
Monoballs are not required. I had the same issue until I swapped my stock suspension out for some good coilovers.
11-20-2017, 10:03 AM | #5 |
10
Rep 87
Previous owner did these Mods:
Vorschlag Camber plates >>> -3.3 negative camber on front end H&R Sport springs HD Bilstein shocks with EDC function. Powerflex Race bushings installed in most front and rear postions. Bimmerworld Precision Front Lower Control Arm Bearing installed. Stop ST40 BBK in all four corners. Excuse my lack of expertise in suspension setups. Do I need monoballs with the above setup? I'm also about to install Bilstien Clubsport coilovers, so wondering if I need to hold off on the monoballs or they are must haves. |
11-20-2017, 10:07 AM | #6 |
Stop the hate, get a V8
3850
Rep 8,625
Don't take this personally, but are you sure it isn't a technique problem? I used to have problems with this until I focused on braking "correctly".
Past: 2011.5 M3 sedan ZCP |
cherry-m317.00 |
11-20-2017, 12:00 PM | #8 |
424
Rep 1,325
Could it be due to aggressive alignment. If you think about it, with -3.3 camber, you have less tire contact patch against the ground?
I remember having some similar issues when first getting some more aggressive alignment (-2.7 camber front). I asked my alignment guy and thats what he explained. But I think it is a potentially a multi-factor problem: Alignment, driver brake technique, suspension pieces, etc. For me, additional track time and brake technique solved a majority of it, and really just knowing what to expect and how to avoid it.
11-20-2017, 12:23 PM | #9 |
379
Rep 875
I would check alignment and tire pressures first. Also, just a thought, if you're slowing the car from 140 mph, depending on how much speed you're reducing to, you're transferring a lot of weight to the fronts and the rear will get light.
11-20-2017, 12:57 PM | #10 | |
17
Rep 90
Proper brake technique especially with grabby brakes is also important.. think of the braking zone as 12345 in terms of least to most pressure. Also you stated having a BBK upfront, are you stock on the rears? |
11-20-2017, 01:13 PM | #11 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
I think you are running to much camber. also i agree braking technique can be a factor here.
Do you have in car video or data we can see?
11-20-2017, 04:19 PM | #13 |
10
Rep 87
Thanks for the input all! I will work on the most important mod, improving the driver and then see if the coilover suspension and monoblocks make a difference in the further future.
11-20-2017, 06:50 PM | #14 |
3900
Rep 4,165
Some twitchiness under hard braking is normal with a lot of cars. Car shd not swap ends though. Could also be worn shocks causing too much weight transfer to the front.
11-20-2017, 07:30 PM | #15 |
433
Rep 1,286
What exactly do you mean by the car is squirrelly? In my car with stock calipers but running track pads my car at RA prior to 10a and prior to turn 1 used to feel uncomfortable same at VIR prior to turn 1 and at the end of the back straight.
If you are experiencing the rear of the car "dancing" around but still tracking relatively straight that's not that uncommon. I don't think it's a "braking technique" issue, I suspect your under maximum threshold braking and the car just feels a bit wobbly in back. Not uncommon some cars do it and some don't. I've felt the same sensation in late model Porsches as well. Slightly unnerving but not really a problem. Are you still tracking relatively straight under heavy braking? I honestly don't think the mono-ball upgrade will have any bearing on straight-line braking performance. If you trail brake into some of those corners listed above it will be a bit more solid (with the mono-ball upgrade) but I don't think there's any detectable difference in a straight line. |
11-20-2017, 10:51 PM | #17 | |
11586
Rep 12,728
what pad compounds are you running?
Instagram; @roastbeefmike
11-21-2017, 10:51 AM | #18 | |
3850
Rep 8,625
At your next track day, try adjust your braking technique to see if that helps. Just focus on that for an entire session. I used to have a bad habit (probably from driver's ed) of just mashing the pedal as hard as I could. This certainly works, but if you come off the gas too fast and get into the brakes too fast, the weight transfer is very abrupt and unsettles the car. I found that being a bit less violent made a world of difference, but it was tough to condition my foot not to just slam the pedal.
11-22-2017, 01:24 PM | #19 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I got the same thing in my E90 with the stock brakes and same pads front and rear. Went away with a 4 wheel BBK. I suspect that you need a little less front bias. One time, I ran pagid yellows on front, blacks on the back wit the stock brakes and the car felt fine. The pagid blacks have more bite and torque than the yellows.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-24-2017, 10:56 AM | #20 |
Retired Curmudgeon
2985
Rep 4,047
What tires are you running on track? I've had the squirrelly feeling when I was on full tread depth RA-1s (putting a heat cycle in the rain tires back in the day). If your tires are near full tread depth, you can get this feeling.
bigjae1976 is spot on with brake bias perhaps being the issue. Since your instructor had the same issue (and not all "instructors" are the same quality, but we'll assume yours was competent), brake bias may be the cause assuming it isn't tires.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
11-29-2017, 05:42 PM | #22 |
1571
Rep 8,076
ROFL! ...that's messed up!
Hopefully others get the unintended joke. ?
