BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      10-31-2017, 12:31 AM   #1
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
255/40 R18 Square Winters E92
Anyone know if 255/40/R18 works on the E92 M3?
I am planning to go square size for this winter.
Please let me know if anyone has any experience with this.
My car is not lowered. Just factory suspension for now.
      10-31-2017, 02:39 AM   #2
Times Like This
12
Drives: E92 M
Depends on the wheels. I've run this setup on OEM 219's without a single issue.
      10-31-2017, 10:08 AM   #3
pbonsalb
5234
Drives: 18 F90 M5, 99 E36 M3 Turbo
I run 255/40/18 and 235/40/18 on stock wheels for winter. Just one step down from stock. My thought was that thinner cuts through snow better and that the tires should be staggered since the wheels are staggered.
      10-31-2017, 10:33 AM   #4
GORDON.M3
GORDON.M3's Avatar
1423
The wheels are not aggressive one bit. I'm not sure of the offset but I'm sure they are roughly in the 35s.
      10-31-2017, 02:20 PM   #5
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
Yup, I don't see why it would be an issue.
I run 225 front and 245 rear on the oem 18's for winter. Works great!
      10-31-2017, 02:48 PM   #6
GORDON.M3
GORDON.M3's Avatar
1423
My biggest concern is 255 being too wide for the front and won't clear the liners.
      10-31-2017, 03:22 PM   #7
SYT_Shadow
SYT_Shadow's Avatar
11490
Not too wide for sure, but perhaps too tall. 275/35 fits without much rubbing.
You can't do 255/35 all around?
      10-31-2017, 04:47 PM   #8
GORDON.M3
GORDON.M3's Avatar
1423
Found a deal on 255/40, it was previously installed on a F80. Should be fine no?
      11-01-2017, 06:59 AM   #9
SYT_Shadow
SYT_Shadow's Avatar
11490
the only possible issue you'll have is the total diameter of the tire
Likely is ok though
      11-02-2017, 06:10 PM   #10
buddalun
buddalun's Avatar
679
Drives: 911 x 2, Tesla M3P & MYP
Likely is ok though
Thanks, SYT. I have a related question:
I plan to run 18x9.5 23mm front wheels on stock ZCP suspension. Do you believe a 255/40/18 tire will fit without issue? TIA.
      11-02-2017, 06:53 PM   #11
GORDON.M3
GORDON.M3's Avatar
1423
Not sure but check here too.
http://www.m3post.com/forums/showthread.php?t=1423450
      11-03-2017, 12:18 PM   #12
SYT_Shadow
SYT_Shadow's Avatar
11490
I believe so, yeah. The ET is not that aggressive (may need some camber) but you'll be fine
buddalun679.00
      11-03-2017, 12:52 PM   #13
GORDON.M3
GORDON.M3's Avatar
1423
Does anyone know what the recommended tire pressure for 255/40/18 Square is?
      11-03-2017, 02:57 PM   #14
buddalun
buddalun's Avatar
679
The OE Pressure for the factory 245/40/18 is 33 PSI and the OE Pressure for the 265/40/18 is 35 PSI as seen on the door jamb picture, below. I imagine running 35 PSI would be perfectly fine.
      11-03-2017, 02:58 PM   #15
buddalun
buddalun's Avatar
679
Thanks SYT.
Since I am on sock suspension and cannot dial in much more negative camber, do you think it would work? Planning on using Michelin PSS in 255/40. TIA!
      11-03-2017, 03:30 PM   #16
SYT_Shadow
SYT_Shadow's Avatar
11490
I run a good old 35 on all my street cars, front and rear. May not be ideal but it's close to correct and very easy to remember
      11-03-2017, 03:35 PM   #17
SYT_Shadow
SYT_Shadow's Avatar
11490
Thanks SYT.
I compared your 255 to the oem tire size for the E92. You're only 1.2% bigger, so you are *perfectly* fine.
Sorry, for some reason I guess I remembered the 19" wheels which have a lower profile than the 18"
I also checked the ET and you're good there as well. OEM has ET29 and you're a tiny bit more aggressive, but OEM also has space for like a 20mm spacer (effectively ET09) so you have tons of room everywhere
buddalun679.00
      11-03-2017, 03:35 PM   #18
GORDON.M3
GORDON.M3's Avatar
1423
That's my rule of thumb also. I do 34psi square.
SYT_Shadow11490.00
      11-03-2017, 04:57 PM   #19
GORDON.M3
GORDON.M3's Avatar
1423
Thanks, my doorjam only showed 19" PSI that's why I didn't know what the 18" pressures were.
      11-03-2017, 07:57 PM   #20
buddalun
buddalun's Avatar
679
Thank you!
      11-08-2017, 07:58 PM   #21
GORDON.M3
GORDON.M3's Avatar
1423
255/40/18 does not work!! It rubs the liner and maybe the cooler too!
When I turn I hear rubbing noises..
      11-09-2017, 07:09 AM   #22
pbonsalb
5234
Why did you run 45 series?
jfull26.00
m3post
