10-27-2017, 01:12 PM | #1 |
99
Rep 382
FS: Fall Line Motorsports F8X M3 / M4 Rear Camber Shim Kit
*********** SOLD *************
FOR SALE: New, never installed Fall Line Motorsports F8X M3 / M4 Rear Camber Shim Kit for all F80 M3 and F82 M4 models. SKU : FLM-F8X-1BSHM "When setting an M3 or M4 for high performance driving, properly setting the rear camber and toe will yield significant results. The rigidly mounted rear subframe and relatively low count of rubber bushings in the back of the car means that alignment changes translate very directly into the car’s behavior, and can be felt immediately when a change is made. The factory eccentric suspension bolts have a reasonable amount of adjustment range for a variety of ride heights and possible alignment settings, but are not a perfect solution. The rigid camber shims will allow a technician to precisely set camber by choosing one of 5 shim offsets to install in the rear suspension. The shims can be used in either the normal orientation, or flipped, resulting in 9 different positions, divided into 1mm increments. This will give an exact camber setting, and ensures absolutely no change in alignment even in the harshest driving conditions." MSRP is $165 USD = approx $255 landed in Canada Will sell for $150 CAD shipped within Canada Last edited by Tuner1; 10-27-2017 at 05:14 PM.. Reason: sold |
10-27-2017, 04:34 PM | #2 |
Bored at work....
890
Rep 5,391
PM sent
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
11-03-2017, 01:50 AM | #3 |
Bored at work....
890
Rep 5,391
Sold to this guy
